Old 06-26-2012, 01:26 PM   #1
btunny's Avatar
tile over plywood?
My husband and I just built a platform bed and would like to tile it so I'm wondering can I just tile right over the plywood or will that not work?
btunny is offline   Reply With Quote
Old 06-26-2012, 07:04 PM   #2
tile over plywood?
I would suggest using a cement board aka durrock. The tile will adhere to it much better. Some of the tile guys/gals on here might know of a better product as I know they are constantly coming out with new stuff.
RhodesHardwood is offline   Reply With Quote
Old 06-27-2012, 12:02 AM   #3
Tileguy
JazMan's Avatar
tile over plywood?
Hi Btunny,
You can not tile directly over a single layer of plywood (subfloor), you would need to add an underlayment of at least 3/8" ply or thicker. That is IF the framing was built sturdy enough. Can you tells us how this platform is constructed and with what?
If the framing meets standards you're better off installing a tile backer board or a membrane such as Ditra if you're able to buy just a small amount.
Jaz
Tile 4 You LLC Troy, MI
KERDI Shower Specialist ... DITRA Installs ... Product-Method suitability consultation. I have NEVER made a mistake, I thought I did once...........but I was wrong! - PRODUCTS ADVERTISED WITHIN MY POST ARE NOT ENDORSED BY ME!
Tile over Tile ?? Piney Flooring 17 02-06-2012 10:59 PM
Tile over Painted Lightweight Cement New_2_DIY Flooring 16 08-28-2011 03:29 AM
coverin plastic tile wall with panelin or thin plywood. how to cover the seams? chinolofus Remodeling 2 11-23-2010 07:52 PM
Need help from tile experts please!! Kara75 Flooring 13 11-20-2010 04:31 PM
Removing kitchen tile with plywood under it ediconu Flooring 4 08-26-2007 09:48 PM
