Tile Over Patio - Flooring - DIY Chatroom Home Improvement Forum
Old 04-15-2011, 11:22 PM   #1
tile over patio
Is it possible to use slate tiles to cover an outdoor concrete patio. Is slate durable?
User111226 is offline   Reply With Quote
Old 04-16-2011, 07:11 AM   #2
DIY staff
Rewards Points: 7,174
A lot depends on your location--where are you?
Slate is made up if many layers---when subjected to water and freezing the layers often pop apart.
A better choice would be a porcelain tile (perhaps one that looks like slate)
Old 04-16-2011, 12:38 PM   #3
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
Look at Daltile Continental Slate or American Olean Highland Ridge. Both are colorbody porcelain tiles that simulate a slate look. Also put down an antifracture membrane before laying the tile. Something like Ditra.
poppameth is offline   Reply With Quote
Old 04-16-2011, 12:56 PM   #4
Too Short? Cut it Again!
Slate also tends to be hard and brittle so you need to be sure your surface is level or it will fracture on you. I would be inclined to use a fired ceramic or porcelain rather than stone too.
Old 04-16-2011, 05:54 PM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
If by "slate" you are suggesting the inexpensive slates available at all of the home centers I would recommend against using that product out of doors. In addition to all of the above-mentioned issues, that particular slate product will also contain plenty of iron oxides that will in a short time turn everything orange and rusty. The oxidation will rise to the surface and migrate into all of the stones. Sealing the surface won't help or change anything. That stuff is the pits.
XXX
Tile over Tile ?? Piney Flooring 17 02-06-2012 10:59 PM
Vertical tile on wall poolecw Flooring 2 06-01-2010 11:05 AM
Where do I make my tile cuts for the wall? petsparkle Kitchen & Bath Remodeling 6 04-25-2009 11:00 AM
Ceramic tile over existing (full mud) ceramic? rjniles Flooring 7 12-24-2008 07:12 PM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 04:31 PM
