Old 05-24-2006, 02:32 PM   #1
They're all fixer-uppers
J187's Avatar
To tile over old tiles or not?
Getting ready to change the tile on my bathroom floor. Its ugly but its in good shape. Its well bonded to the concrete underlayment. I'm wondering is it best to tear up the old tiles or just go right over them. I know I have the option both ways, I just don't know which is best.
J187 is offline   Reply With Quote
Old 05-24-2006, 06:26 PM   #2
If none are loose, tap on them, if it sounds hollow anywhere, remove it all, if solid and the added height isn't a problem, you can go over them with a good modified thinset.
Oh wait, you asked which is the best way, removel of all the old and redoing the substrate is best, but if solid, no loose grout and cleaned, don't see a problem, it's done all the time.
R&D Tile is offline   Reply With Quote
Old 05-25-2006, 09:48 AM   #3
J187's Avatar
And If I did decide to remove the tiles first, I'd have to redo the substrate as well? Its an 11/8 concrete slab and Would not be fun to try and take up I'm sure. I don't think I'd mind taking up all the old tiles, but I dont' think I have the time to redo the substrate...
Old 05-26-2006, 12:44 AM   #4
Carpenter
DecksEtc's Avatar
You don't necessarily need to re-do the substrate or take it up. I am in the midst doing a similar job on my own home, albeit a smaller area. What I am experiencing by taking up the old tile (it was a horrible tiling job) and what I think R&D is referring to is that when you remove the old tiles & thinset, parts of the concrete floor will come up with it. So, you need to properly prep the concrete floor. What I am doing to get the floor prepped for the new tile is using self leveling concrete to get the substrate ready for the new thinset and tiles.
Hope this helps...
Terry
DecksEtc is offline   Reply With Quote
Old 05-26-2006, 08:41 AM   #5
J187's Avatar
So you are using self leveling concrete to fill in the areas that come up? I'm not sure I trust myself with concrete to ensure a perfectly level surface - I know that's why its usually only pros that use concrete. I guess its something to ponder for a while. Thanks.
Old 05-26-2006, 05:53 PM   #6
When you say concrete underlayment, are you talking about a slab, a backerboard or a couple inches of mud over a wood floor?
Old 05-27-2006, 03:05 PM   #7
Floorwizard's Avatar
Best to start brand new.
Floorwizard is offline   Reply With Quote
Old 05-30-2006, 08:30 AM   #8
J187's Avatar
Sorry, 1" 1/8 Slab of concrete.
Tile over Tile ?? Piney Flooring 17 02-06-2012 10:59 PM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 04:31 PM
Shower Tiles Easily Pop Out - Bad Installation? kabowma0 Remodeling 6 04-23-2007 08:43 PM
Tile roof questions/repairs help please xoroniox Roofing 3 12-17-2006 03:02 PM
Tile and laminate, or get rid of tile? kfoster Flooring 10 03-17-2006 03:14 PM
