Old 07-12-2009, 04:13 AM   #1
Tile over Oak Hardwood floors (unfinished)
I have a 1960's house, original oak wood floors. I had carpet but got rid of it. Wood is in very good condition (as I've been told by experts I've had come over to give quotes). no creaking or anything. Very strong.
My mom and I are HIGHLY chemically sensitive and though we've looked at many types of finishers/sealers (even one with zero voc), we noticed all have a smell, even if it's a strong oil smell. We can't handle it.
Decided to just tile the front room and dining room. Looked into using a backboard that we had another company use to do the entry way. We were going to do it ourselves next week.
Then, I found a video on Youtube that hardwood should be finished to put tile on it because of the water (?) in the concrete/grout? Is this true because on another website I found it says, "if you don't feel like refinishing your hardwood floors, why don't you try tile" and gives instructions.
The man is the youtube video was putting the tile directly on the wood, which we're not doing, but still. I never thought about the moisture until now.
So confused. Obviously, I won't be laying the tile on the wood, but is there anything I can use (along with the backboard) to make sure that none of the wetness goes into the wood?
thanks for your help
irishgem@ymail. is offline   Reply With Quote
Old 07-12-2009, 04:18 AM   #2
Let me also add that while the wood is in good condition, there are are dirt/wear stains. There's one like in the center of the front room that has the wood lighter in one area. Experts said that even if they (or we) sand the floor that part may still show up (lighter than the rest, unless we stain). No expert has said the wood needs to be fixed or there's water damage, so I am not worried about that.
So while it would be A LOT cheaper do keep the wood floors, to risk having a spot like that in the middle of the floor would not look good. This is why we think tile will be better.
Old 07-12-2009, 12:35 PM   #3
The proper way would be to remove the flooring and then start with laying down a good plywood if you have too much deflection in your flooring. Ditra is much faster and does a better job than cement board.
Now, you could do just what you saw on the internet, and it might hold up well, but it's a risk you shouldn't take. The oak is going to move around on you and might cause the grout to crack a few years down the road.
Josh Jaros Remodeling in The Woodlands, Texas
jaros bros. is offline   Reply With Quote
Old 07-13-2009, 10:07 AM   #4
Flooring Materials
fastfloors's Avatar
I've got to agree with Jaros Bro. Make sure you take the time to do it right
fastfloors is offline   Reply With Quote
restoring hardwood floors buried under tile and the cement sheets tiles are on bobblehead Flooring 10 05-15-2013 09:13 AM
5 Ways to carry on your hardwood floor shining brightly John_smith Flooring 3 02-24-2009 12:56 PM
tile over hardwood floors MnMan Flooring 1 07-30-2008 06:39 PM
Easy maintanence and child friendly Hardwood floors? gante Flooring 2 03-11-2008 09:04 AM
Hardwood floors: Removal of carpet staples, dried paint, and a discoloration problem proofer Flooring 7 03-01-2008 08:06 AM
