Tile Over Linoleum - Flooring - DIY Chatroom Home Improvement Forum
Old 01-17-2011, 03:21 AM   #1
HandyAndyMan's Avatar
Tile over Linoleum
I am going to be finishing off a downstairs basement bathroom. The bathroom has 12x12 self adhesive Linoleum squares installed as flooring (over the concrete). Removing this flooring is a pain from what I have heard. Could I put some type of underlayment/plywood over the top of the linoleum and then tile the room? Or am I stuck trying to remove the existing flooring?
Secondly, how do I raise the toilets sewer pipe elevation to match the tile floor?
Many Thanks!
HandyAndyMan is offline   Reply With Quote
Old 01-17-2011, 06:10 AM   #2
DIY staff
Rewards Points: 7,174
The tiles should be pealed off---It's a pain but you can do it----usually a scraper and a hammer is all that is needed----A multi tool with a scraper is a time saver if you have one---A heat gun also helps.
Worst case --the tiles are stuck forever?--Use a two part thinset like Kerabond and Keralastic--That will stick nicely to the old tiles--as long as you strip off any wax or dirt.
Never ever put plywood over a concrete floor---that nearly always fails.
Mike
Old 01-17-2011, 06:18 AM   #3
woodman58's Avatar
It is not recomended to go over a tile floor. That said, I have done it many times. You will need to make sure all tile are glued tight to the floor. You cand go dirrectly over tile or a ditra sub-flooring. Box stores carry this.
As for the raising the floor, when you get a new wax ring for the stool, purchase a jumbo wax ring. then get just a regular wax ring and, if needed cut in 1/2 and put on top on other ring. If you have a straight pipe for the supply line you will need to get a new supply line for toilets and stool bolts. Get the 3 and 1/2 inch ones. You will need a hack saw to cut the bolts to put the caps on.
woodman58 is offline   Reply With Quote
Old 01-17-2011, 06:19 AM   #4
Yeh, I think I found a floor scraper I can rent to do the job.. or make it easier..
Also I found an adapter that will raise the toilet flange up to the new elevation with the tile..
Old 01-17-2011, 08:26 AM   #5
Rewards Points: 200
The toilet flange is the proper way to do it .
I inspected a few wood floor failures in powder rooms where the plumber , or installer put a double wax ring .
Floor Doc is offline   Reply With Quote
Old 01-17-2011, 08:59 AM   #6
Why don't you use Allure from Home Depot? No need to remove existing flooring.
stary kozel is offline   Reply With Quote
Old 01-17-2011, 04:19 PM   #7
Allure
I never knew of Allure until you mentioned it.. I have my heart set on tile for the bathroom, however, I am thinking Allure might be an option for the workout room. Thanks for the tip!
Old 01-17-2011, 04:27 PM   #8
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 84
I would suggest that you read some on the threads on here concerning allure before you decide if you want it.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 01-17-2011, 04:37 PM   #9
Absolutely..
Tile over linoleum Wolfefam Flooring 12 02-25-2013 12:00 PM
20x20 Porcelain Tile over Linoleum on Concrete Slab scbauer Tiling, ceramics, marble 3 08-31-2010 07:11 PM
Tile Baseboard on outside of plastic shower pan at linoleum joint? GaryS Tiling, ceramics, marble 2 07-26-2009 12:39 PM
Pulling up old tile or linoleum to replace it. RyanD General DIY Discussions 4 03-25-2009 12:53 PM
Tile over old linoleum? SeattleDuck Flooring 1 09-22-2006 02:58 PM
