Tile Over Concrete With Glue Residue - Flooring - DIY Chatroom Home Improvement Forum
Old 01-12-2012, 09:22 PM   #1
Tile over concrete with glue residue
Hello,
I'm currently working on replacing all the flooring in our main level, which includes a powder room. That area had a builder installed engineered wood flooring that was glued down over concrete, with what seemed to be an excessive amount of adhesive. After renting a commercial floor stripper I was able to get all the flooring up however I was left with a think glue residue. It is patchy and not a solid coating of residue but still enough to have me concerned about proper adhesive with my mortar. The mortar I purchased is Mapei Ultraflex 1. Will this mortar be adequate after scrapping the flooring and sanding it to remove as much of the residue as possible? If that isn't possible is there a way I can attach a CBU to the subfloor? I want to do this right the first time. I appreciate any advice.
Thank you
Eric
ebitler is offline   Reply With Quote
Old 01-12-2012, 09:27 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 84
You can't use CBU on a concrete floor.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 01-12-2012, 09:34 PM   #3
That's what I thought. Is there a mortar that would be acceptable to use that would be effected by the adhesive residue?
Old 01-12-2012, 10:06 PM   #4
I saw on another post where another forum member had a similar issue with vinyl tile adhesive residue left on concrete. It was suggested that he try water as many of the adhesive's were water based. Does this also hold true for wood flooring adhesives? The glue on my floor is also yellow in color and turns to powder when I attempted to sand it. Also I see that the Superflex 1 is a very entry level product. The area I am tiling is only about 45 sq. ft. so cost is not an issue. Is there a higher end product available the big box stores that would yield a higher quality end result?
Old 01-31-2012, 10:36 PM   #5
analogmusicman's Avatar
Rewards Points: 560
I've been told in this forum that the only way to reliably get rid of adhesive on concrete is by mechanically taking it off. forget about removers or scrapers,you'll wear yourself out! get an "angle grinder" and a "diamond blade". (that's what I did on my front slab) be prepared for dust like you wouldn't believe!
tnx,
analogmusicman is offline   Reply With Quote
Old 02-01-2012, 01:30 PM   #6
firehawkmph's Avatar
Rewards Points: 1,864
Eb,
I have decent results with removing adhesive with a heat gun and stiff putty knife or scraper. It stinks a bit, but the gun should soften up the glue so you can easily scrape it off. Watch the heat gun near the bottom plates, don't let it get to hot. Have a bucket of water and sponge handy just in case.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 02-01-2012, 03:59 PM   #7
DIY staff
Rewards Points: 7,174
You could encapsulate it with a self leveling compound----I suggest Jifset mixed with Lineweber liquid latex--
Other wise read the instructions on what ever brands are available to you.
A picture of the glue mess would help---and the type of glue if you have any idea what it is.
Concrete floor over tile Cellomangler Flooring 13 08-25-2012 06:45 PM
Leveling concrete subfloor with old tile mefferz Flooring 4 11-05-2011 05:13 PM
Ceramic floor tile on concrete basement floor w/toilet pedestal amp2oo1 Flooring 1 10-05-2009 07:31 AM
Concrete chip repair prior to ceramic floor tile? libbybuddy Flooring 2 06-10-2009 04:54 PM
Tile over concrete moneymgmt Flooring 4 10-26-2007 08:46 AM
