Tile Over Concrete - Flooring - DIY Chatroom Home Improvement Forum
Old 10-23-2007, 09:57 AM   #1
Rewards Points: 256
Tile over concrete
My utility room has 1x6 covered by subfloor covered by 3/4" of concrete. There is tile down now that looks like a cross between peel-and-stick and regular tile, its about 1/8" thick, all seams butt together, and any side pressure at all pops them off. I want to rip them out and put nice tile over the top as we're renovating that room. Can I tile right over the concrete or do I need put put down backer board? There's no way I'm ripping out the concrete but the surrounding rooms right now are at an even height so I'm hoping the concrete will bond.....
moneymgmt is offline   Reply With Quote
Old 10-26-2007, 08:13 AM   #2
Yes you can set tile directly onto concrete.
KenH83 is offline   Reply With Quote
Old 10-26-2007, 09:21 AM   #3
yes if your concrete show no sign of cracks so that means no movement....
KUIPORNG is offline   Reply With Quote
Old 10-26-2007, 09:26 AM   #4
Rewards Points: 256
I'll look when I pull up the current tile but since its about 3/4" concrete sitting on subfloor and joists I don't see how it could shift/crack without the rest of the house doing so.
Thanks guys, I love it when you tell me what I want to hear, especially on a Friday!!!
Old 10-26-2007, 09:46 AM   #5
The best answer for your situation is Edge Flooring. With traditional tile over a concrete floor you can get reflective cracking which is when the concrete cracks it will mirror that exact crack in the ceramic tile. Also any hydrostatic pressure can push mouisture up through the slab. With Edge its real tile that "floats" so cracks are irrelevant. You may want to check out www.edgeflooring.com to see it and if you have questions just hit me back. Usuing Edge over your concrete slab is the perfect answer for what your up against. Best of luck with the project.
EdgeMan is offline   Reply With Quote
Concrete floor over tile Cellomangler Flooring 13 08-25-2012 07:45 PM
tile over exterior concrete? BlueMoonBean Flooring 6 11-18-2008 02:55 PM
Concrete basement slab + Radiant + Tile MageMinds Flooring 4 08-21-2007 01:52 PM
Pulling up tile and laying bamboo on concrete kdhughes Flooring 2 07-20-2007 12:11 AM
Tile on concrete slab, ground level - bamboo? IvoryRing Flooring 2 06-28-2006 09:52 AM
