Old 11-19-2011, 09:57 PM   #1
Tile over brick
I'm recarpeting my living room but would like to tile the entry from the back porch. Under the carpet is a brick veneer is what you would call it. It seems very structurally sound. My question is, can I tile right over that with an ultra flex mortar? Any prep before laying? Thx
Stanchek is offline   Reply With Quote
Old 11-20-2011, 06:08 AM   #2
Super Moderator
Tile over brick
pictures would help--but it sounds like any good modified thinset should work.
Old 11-20-2011, 01:43 PM   #3
Msradell's Avatar
Tile over brick
Of course if it really is just a thin veneer it may be very easy to remove its height of the final assembly was going to be a problem.
Msradell is offline   Reply With Quote
Old 11-20-2011, 01:50 PM   #4
Tileguy
Bud Cline's Avatar
Tile over brick
No, that's what YOU would call it, but what is it really? This brick product should be positively identified before you try to cover it with tile.
Old 11-20-2011, 01:55 PM   #5
Tile over brick
Well, it's about an inch thick. Is that considered a veneer?
Old 11-20-2011, 01:56 PM   #6
Tileguy
Bud Cline's Avatar
Tile over brick
So it is real live "pavers"?
What's between the "bricks"?
Old 11-20-2011, 02:05 PM   #7
Tile over brick
Well I haven't torn any out, but from a spot on the edge where I can see down there a bit, it looks like a fairly thick mortar bed on top of plywood.
Old 11-20-2011, 02:18 PM   #8
Tileguy
Bud Cline's Avatar
Tile over brick
What's between the "bricks"? (If anything)
Sounds as if they are pavers and they should be substantial if they are in a mortar bed. If they aren't moving then they should be safe to go over.
Old 11-20-2011, 02:38 PM   #9
Tile over brick
Old 11-20-2011, 02:44 PM   #10
Tileguy
Bud Cline's Avatar
Tile over brick
If it were me I would pour Self Leveller over the bricks first. I doub't that will be very easy to apply tile to otherwise.
The Following User Says Thank You to Bud Cline For This Useful Post:
Msradell (11-20-2011)
Tile over Painted Lightweight Cement New_2_DIY Flooring 16 08-28-2011 03:29 AM
HELP! with brick tile floor cpmathis Flooring 0 09-03-2010 11:58 AM
Question Re. Parging Over Brick Captain.Sassy Building & Construction 19 06-22-2010 09:50 AM
tile man used mastic glue on entrance to shower keyesww Tiling, ceramics, marble 13 06-08-2010 05:39 PM
Insulating brick above & close to grade Peter Shepherd Building & Construction 1 09-16-2009 07:41 AM
