Old 10-25-2011, 11:36 AM   #1
Tile to Molding Transition
Hi... I am going to tile the left area of the image and tile up the wall as a border...I am putting molding down above the platform... are there any creative ways I can join these 2 materials so it does not look like this?
joshy is offline   Reply With Quote
Old 10-25-2011, 07:51 PM   #2
41 years in construction
Consider installing a plinth block at the end of the wood base. It will provide a "termination point for both the wood and tile bases. Plinth blocks are sometimes used at the bottom of door frame casings. They are usually around 1" thick by 4" to 6" tall by 3.5" to 4" wide. Some include bevelled edges or filagree such as turned rosette or star. They are available at your local big box store.
Rick
Arkitexas is offline   Reply With Quote
Old 10-25-2011, 09:51 PM   #3
firehawkmph's Avatar
Josh,
The plinth block would be fine. If you don't want that, I would at the very least miter and return the end of the base molding into the wall so it looks finished. Then maybe some kind of trim tile going up the wall vertically with a bullnose edge on the right so it looks finished.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Dricore to tile transition BlueBSH Building & Construction 7 04-14-2011 10:24 AM
Tile landing Carpet stair Transition Tmint Flooring 1 02-04-2011 05:35 AM
Crown Molding Transition over narrow gap between ceiling and window top ... NallaChiruta Carpentry 4 02-11-2010 08:34 AM
Transition laminate to higher fireplace tile Slippin Flooring 1 03-17-2009 09:22 PM
carpet to tile transition jeeper36 Flooring 1 10-26-2007 11:16 PM
