Tile Maintenance? - Flooring - DIY Chatroom Home Improvement Forum
Old 05-02-2008, 10:52 AM   #1
tile maintenance?
I was just wondering if there's any longer-term maintenance that should be done with tile (just regular ceramic, I believe), such as waxing or sealing?
joeyboy is offline   Reply With Quote
Old 05-02-2008, 11:04 AM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Nothing required for ceramic tile other than occasional cleaning and maybe re-sealing of grout under some circumstances.
Old 05-02-2008, 11:31 AM   #3
alright so glaze is for other types of tiles then? I dunno about sealing grout on these, the grout's dark so it looks good (wish I could say the same about the bathroom's lines!!)
Old 05-02-2008, 12:25 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
"Glaze"????
Where is that coming from? Most ceramic tile is glazed, I assumed you were talking about glazed ceramic tile.
Can you volunteer some more information.
Old 05-02-2008, 02:09 PM   #5
ayeshaa's Avatar
Do's and Don't of Ceramic Tile Care
  1. Do not combine ammonia and household beaches.
  2. Do not use harsh cleaning agents (such as steel wool pads), which can scratch or damage the surface of your tile.
  3. Do not use a cleaning agent that contains color on unglazed tile. It has a relatively porous body and may absorb the color.
  4. Do test scouring powders in a small area before using on tile.
  5. Do use silicone sealer on grout joints if continuous staining is a problem.
  6. Do read and follow label directions for all cleaners.
  7. Do see your nearest Tile distributor for advise on special cleaning problem or if you have any question
hope it helps
Last edited by Ron The Plumber; 05-07-2008 at 09:24 PM. Reason: Removed link to website
ayeshaa is offline   Reply With Quote
Old 05-02-2008, 05:34 PM   #6
Originally Posted by Bud Cline View Post
"Glaze"????
I thought it was a glaze, must've been a wax
Basically, the tiles in my kitchen are, presumably, pretty old. I figured that if there is any waxing/sealing/glazing/etc that is an option/recommendation, it'd be a good idea to go for to keep the average cleanings sweepings and not moppings
Tile over Tile ?? Piney Flooring 17 02-06-2012 09:59 PM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 03:31 PM
Some questions about laying Tile? DiY_RooK Flooring 1 08-31-2007 09:35 PM
Subway tile installation bigboyjoel Flooring 3 08-02-2007 07:15 AM
Tile and laminate, or get rid of tile? kfoster Flooring 10 03-17-2006 02:14 PM
