Tile Landing Carpet Stair Transition - Flooring - DIY Chatroom Home Improvement Forum
Old 02-03-2011, 11:11 PM   #1
Tile landing Carpet stair Transition
So I am redoing my stairs and landing for the split level entry way.
The landing is going to get tile and stairs will be carpeted.
I am not sure how I should deal with the transition from the tile landing to the carpet on the lower set of stairs.
Do I bring the backer board and tile to the edge, then use some sort of transition strip ?
I also have steel hand railing that attaches to the landing using lag bolts, how can I reattach the railing ? On top of the tile or just on top of the backer board tile around it.
Will update with pics, might be more explainable.
Tmint is offline   Reply With Quote
Old 02-04-2011, 04:35 AM   #2
DIY staff
Rewards Points: 7,174
You will want an oak stair nosing---that will require you to cut back the plywood nosing in order to get the proper set--to the other steps.
Install the nosing on top of the backer board---you will need a table saw or router to cut the piece the same thickness as your tile and thinset.
I think the handrail needs to be on top of the tile----make it easier to add a new handrail in the future.
Laying Carpet over a ceramic tile floor cgriend Flooring 1 01-02-2011 08:39 PM
Carpet dug up by cat, cracked tile beycattrules Remodeling 1 04-08-2010 06:37 PM
Transition from grouted vinyl tile to carpet MI-Roger Flooring 2 11-29-2009 12:55 PM
Tile baseboard with carpet? bpak04 Flooring 2 11-03-2008 12:28 PM
Gaps at baseboards after carpet install cometbus Flooring 9 10-01-2007 07:48 PM
