-   -   Tile landing Carpet stair Transition (http://www.diychatroom.com/f5/tile-landing-carpet-stair-transition-94482/)
Tmint 02-04-2011 12:11 AM
So I am redoing my stairs and landing for the split level entry way.
The landing is going to get tile and stairs will be carpeted.
I am not sure how I should deal with the transition from the tile landing to the carpet on the lower set of stairs.
Do I bring the backer board and tile to the edge, then use some sort of transition strip ?
I also have steel hand railing that attaches to the landing using lag bolts, how can I reattach the railing ? On top of the tile or just on top of the backer board tile around it.
Will update with pics, might be more explainable.
http://img819.imageshack.us/img819/6...0202123308.jpg
http://img3.imageshack.us/img3/2158/20110203224521.jpg
oh'mike 02-04-2011 05:35 AM
You will want an oak stair nosing---that will require you to cut back the plywood nosing in order to get the proper set--to the other steps.
Install the nosing on top of the backer board---you will need a table saw or router to cut the piece the same thickness as your tile and thinset.
I think the handrail needs to be on top of the tile----make it easier to add a new handrail in the future.
