Tile A Lanai Or Other Ideas? - Flooring - DIY Chatroom Home Improvement Forum
Old 01-13-2009, 07:05 AM   #1
Rewards Points: 150
Tile a Lanai or other ideas?
I have a condo in Florida that has a small lanai (120 sq ft).
Right now, it is just rough painted concrete and is a didaster to clean up.
I want to get a surface on there that I can mop clean so it needs to be smooth.
My initial though was tile. If I use tile, can I just get the pre made thin set from the Depot and us that right on the concrete to set it? Anything else I need to be aware of?
Also, is there any other option like a skim coat of concrete or somthing easier?
dcd22 is offline   Reply With Quote
Old 01-13-2009, 07:26 AM   #2
K&B Remodeler/Tile Guy
angus242's Avatar
In order to tile over cement, it needs to be free of all paints, sealers or adhesives. Also, premixed thinset isn't really thinset at all. It's a form of mastic and you don't use mastic for flooring applications. You want to tile it, you need to grind the paint off and start with a clean cement surface.
Sorry to be the bad news guy.
Angus
My Albums
angus242 is offline   Reply With Quote
Old 01-13-2009, 04:25 PM   #3
Rewards Points: 150
Ok, interesting. Many people have had their done and none were grinded down. I am interested in this as I also thought that would need to be done.
Old 01-13-2009, 04:40 PM   #4
angus242's Avatar
Not sure about the others but I use the TCNA Handbook as a guideline. That's where the info comes from. I'm not making it up as I go.
http://www.tileusa.com/
Angus
My Albums
Tile over Tile ?? Piney Flooring 17 02-06-2012 09:59 PM
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 06:10 PM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 03:31 PM
Some questions about laying Tile? DiY_RooK Flooring 1 08-31-2007 09:35 PM
Tile and laminate, or get rid of tile? kfoster Flooring 10 03-17-2006 02:14 PM
