Tile To Laminate Transition - Flooring - DIY Chatroom Home Improvement Forum
Old 03-21-2008, 07:58 PM   #1
Question
tile to laminate transition
I have a 10' 1" cased opening with a ceramic to laminate transition. I have a wooden T-moulding for a seamless transition because all of the laminate alternative came in only 8' sections. Anyhow, do I need a to use a C-channel to put the strip down? What about Liquid Nail with finishing nails or nail with an air nailer? If I need the C-channel, who would carry it?
SML93 is offline   Reply With Quote
Old 03-21-2008, 08:04 PM   #2
Rewards Points: 774
So you are asking about how to install the T moulding transition strip?
cibula11 is offline   Reply With Quote
Old 03-21-2008, 09:12 PM   #3
Yes, what's the best way to install this?
Old 03-21-2008, 11:15 PM   #4
Boz
Gus
Boz's Avatar
I don't think (not sure) you can buy just the channel alone. I usually just brad nail them. A bead of caulk under the tile side will help keep it from moving around.
Boz is offline   Reply With Quote
Old 03-22-2008, 11:17 AM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
The laminate-related T-Moldings come with their own C-channel. Apparently you have purchased a separate T-molding because of the limited length the others are available in. In this the case?
Old 03-22-2008, 05:11 PM   #6
project complete
Yes, I purchased a wood T-moulding in maple so that I didn't have to have a seam. The seams on the laminate strip were chipping from wear.
I called the local radio guru and he suggested finishing screws and putty over the holes. The sawmill / lumber supplier didn't have any C-channel for that, but they agreed that the finishing screws would work fine. It gave me a tight seal on both sides (tile and laminate) and the real wood matches the laminate pretty closely.
Thanks to all who replied!
Hardwood and Tile Transition Gap mobowhunter Flooring 2 01-19-2008 05:25 PM
Installing Laminate in Kitchen/Ceramic Tile in Hallway ssutton3014 Flooring 1 10-17-2007 11:18 PM
Laminate Floor in Sunken Room w/ Tile on Edge z0s01 Flooring 1 02-20-2007 10:44 PM
Laminate Flooring Transition Question flysndoc Flooring 1 01-29-2007 10:48 PM
Tile and laminate, or get rid of tile? kfoster Flooring 10 03-17-2006 02:14 PM
