Tile Or Laminate Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 07-15-2012, 08:54 AM   #1
tile or laminate flooring
Can't decide on flooring. Think I want tile in living room, but think I might regret it because of the proclaimed "cold" look and feel. I just had a water leak so am gun shy. Any comments would be appreciated. Am feeling pressured to get started by installers, etc. some of which may be self induced. Right now I have no living room floor downstairs.
linda111 is offline   Reply With Quote
Old 07-15-2012, 09:12 AM   #2
Pro
JetSwet's Avatar
Rewards Points: 502
How about engineered hardwood? Looks and feels better then laminate. Although you can get quality laminate like 10 or 12mm grade higher grade the better feel and look.
How did the leak happen and what got wet? Is that issue resolved?
You also can go with tile that looks like laminate, there are a number of options.
JetSwet is online now   Reply With Quote
Thin set vs mesh porcelain floor tile over plywood subfloor and vinyl flooring Jerseygirl Tiling, ceramics, marble 49 05-23-2013 02:04 PM
installing laminate where tile was... mmyers Flooring 5 12-10-2011 07:53 PM
Laminate wood flooring on slab newb questions shark974 Flooring 3 11-11-2011 06:57 AM
How do you install laminate flooring under door casings? Player Flooring 34 07-16-2010 05:55 PM
laminate v. hardwood flooring JDuc Flooring 11 01-13-2008 10:01 AM
