Tile And Laminate Floor Transition - Flooring - DIY Chatroom Home Improvement Forum
Old 07-04-2014, 08:49 AM   #1
Rewards Points: 37
Tile and Laminate Floor Transition
Hello Folks,
Thanks very much for all your assistance. I am installing laminate tiles and I am running into some transition issues with the ceramic tiles they adjoin.
I have a 3/4 inch subfloor. On top of that is a 1/4 inch plywood. The laminate is a tongue/groove (click) type, with an underlayer already attached to it.
I am installing the laminate in a small foyer that sits in front of the laundry room and powder room - both of which have ceramic tiles I installed recently.
Now my issues:
-- First, there is a small (about a 1/4 inch) height (lip) difference between the tiles and laminate tiles (i.e., the tiles slightly taller - - see Figure A & C).
-- Secondly, as Figure B shows, I left about a 4 inch open space in the door-way (between the tiles and laminates).
1. What kinds of transition should I use between the two interfaces?
2. Do the transition strips need to sit directly on the plywood or directly on the subfloor ?
3. Finally, how wide does the transition strip (or space for it) need to be? Is 4inch (between the bathroom and foyer) too wide?
Thanks again for all your responses. Happy 4th !!!
rgds, Oyiwaa
Oyiwaa is offline   Reply With Quote
Old 07-08-2014, 10:15 AM   #2
Rewards Points: 318
I made my own with oak. Tile side is flat against the tile height (tiles installed straight). Floating floor side is rabbeted to cover the floor edge and space for movement and beveled top edge. It went in between the door jambs and stops reinstalled later.
carpdad is offline   Reply With Quote
Old 07-08-2014, 04:08 PM   #3
Rewards Points: 3,348
What carpdad describes is a custom made transition which is what I do also, but I don't think you can buy what he describes, if you have a table router you can make one though.
Canarywood1 is offline   Reply With Quote
Tile on Laminate onthebrinck Remodeling 2 10-26-2012 11:26 AM
Basement Bar Flooring - Laminate & Tile Setzer1994 Flooring 0 04-18-2012 02:28 PM
Replacing tile with laminate - Bad idea? Regina Phalange Flooring 6 11-22-2008 07:12 PM
Laminate Floor in Sunken Room w/ Tile on Edge z0s01 Flooring 1 02-20-2007 11:44 PM
Tile and laminate, or get rid of tile? kfoster Flooring 10 03-17-2006 03:14 PM
