Old 02-02-2011, 07:00 PM   #1
Smile
tile in kitchen questions
So I've removed the old carpet from my kitchen/dinning and cleaned up the subfloor. I'm now ready for the next step to start my tiling but need some help as it's my first tile job over 20 sq ft.
I'm putting in ceramic tile, 1 foot square.
1- I quickly checked the floor and it seems pretty level, if I have to use self leveling compound should I put it over or under backer board?
2- Is it over kill to put down backer board and ditra? if I have to choose, which is better?
3- Can I install a infloor heating pad over the ditra if I choose to use ditra?
Sorry but I need to know before I go any further
rjmvancity is offline   Reply With Quote
Old 02-02-2011, 07:23 PM   #2
Tileguy
Bud Cline's Avatar
A floor does not have to be level to install ceramic tile. The floor should however be flat. Flat and level can be two different things. Backerboard CAN NOT be installed over Self Levelling Compound.
DITRA is by far better. There is no reason what so ever to use both.
Well you can but the floor heat system still requires a thermal-mass of cement to work properly. So if you install the heat product then bury it in Self Levelling Compound you have done all you need to do. The SLC serves as the tile backer underlayment.
The Following User Says Thank You to Bud Cline For This Useful Post:
FlooringDude (02-02-2011)
Old 02-02-2011, 07:29 PM   #3
Sorry Bud, I used the wrong wording, the floor seems to be fairly level and fairly flat, 1/4" or less
Would you say its better to use the backer board in the small area where I'm putting the heating pad and use detra in the rest of the room?
Old 02-02-2011, 07:34 PM   #4
Tileguy
Bud Cline's Avatar
SLC is usually all that is required for the heat system.
DITRA comes in 1/8" and 5/16" thickness.
It takes a minimum of 3/8" of SLC to bury a typical heat mat product.
If you use the 5/16" DITRA you can make it all work out perfectly but the truth is the SLC doesn't cost any more than the DITRA. I would pour the whole thing with SLC and be done with it.
Old 02-02-2011, 08:26 PM   #5
ok so last dumb question I promise. Do I need to put down more plywood or will the stuff that was under the carpet do?
So option 1: Stright to ditra then tile
or
Option 2: plywood, ditra, then tile?
Old 02-02-2011, 08:57 PM   #6
check the deflection and go from there
http://www.johnbridge.com/vbulletin/deflecto.pl
FlooringDude is offline   Reply With Quote
The Following User Says Thank You to FlooringDude For This Useful Post:
oh'mike (02-02-2011)
Old 02-02-2011, 10:22 PM   #7
Tileguy
Bud Cline's Avatar
What is the thickness of the subfloor now?
What is the size of the joist spacing?
What is the size of the floor joists?
What is the style of the floor joists?
Tile, hardwood, and carpet questions ws450r Flooring 1 07-02-2010 02:40 PM
Wall tile - five questions CZ DIY Tiling, ceramics, marble 4 04-24-2010 02:44 PM
kitchen tile floor Lillian Rubin Tiling, ceramics, marble 1 11-02-2009 04:00 PM
Cast iron self-rimming kitchen sink & granite tile ILjXYZ Kitchen & Bath Remodeling 1 01-03-2009 06:53 PM
Some questions about laying Tile? DiY_RooK Flooring 1 08-31-2007 10:35 PM
