Tile Installation With Plank Subfloor, Only 3/4" To Work With - Flooring - DIY Chatroom Home Improvement Forum
Old 05-20-2013, 02:31 PM   #1
Question
Tile installation with plank subfloor, only 3/4" to work with
We're in the middle of a kitchen remodel and are about to start installing a new floor, but I'm not sure if we're going to be able to do it right without it being noticeably higher than the adjacent hardwood.
We removed the old kitchen floor down to the plank subfloor. We found that the hardwood that sits next to the kitchen is 3/4" thick and is separated from the plank subfloor only by a thin moisture barrier.
I'd like my tile job to be pretty much flush with the hardwood. A little higher is okay.
The guides I've seen on the web recommend installing 1/2" OSB underlayment, another 1/2" of cement board, and then the tile on top of that. The tile is 8mm, or about .3", which would mean the completed floor would be more than half an inch higher than the hardwood.
Ditra is only 1/8" thick, but the manufacturer still recommends a 5/8" plywood or OSB underlayment. We'd be more than a quarter inch above the hardwood with that.
Are there products on the market to provide the necessary rigidity and tiling surface to do a half inch of underlayment? It's looking the answer is that I'm going to have to live with a raised kitchen floor unless I want to rip up all the hardwood.
adamsb6 is offline   Reply With Quote
Old 05-20-2013, 02:43 PM   #2
Rewards Points: 13,712
Why not remove the last of the subflooring?
It's not doing you any favors and I'd bet it not all flat.
Once removed you could use 3/4" Advantec T & G and have a flat soil subfloor.
I've never seen 1/2 tile board used on a floor only 1/4". Tile board adds no strength to the flooring it's only for something for the tile to grab onto.
Old 05-20-2013, 03:46 PM   #3
Unfortunately the joists don't line up with the edges of the kitchen. If I cut my planks there, the surrounding finished hardwoor floor would fall into the basement.
Also it's looking like I'd probably want very thick Advantec because my joists are spaced 48" apart.
Old 05-20-2013, 04:45 PM   #4
If there that far apart I'd forget about tile.
The Following 2 Users Say Thank You to joecaption For This Useful Post:
JetSwet (05-20-2013), oh'mike (05-20-2013)
Old 05-20-2013, 06:38 PM   #5
Yep, just got back from looking at luxury vinyl tile. Thanks for replying back so quickly.
The Following User Says Thank You to adamsb6 For This Useful Post:
Old 05-22-2013, 02:34 AM   #6
Rewards Points: 744
Originally Posted by adamsb6 View Post
luxury vinyl tile.
Now, THAT is a perfect example of any oxymoron!!!!!!
Seattle2k is offline   Reply With Quote
Need advice in fixing "contractor's" botched shower floor tile job toocheaptohire Tiling, ceramics, marble 5 10-15-2012 02:31 PM
Floor Installation - Porcelain Tile over VCT...Please help diyuser1999 Flooring 3 05-20-2012 07:48 PM
Asbestos Removal, Porcelain Tile Installation jimbriam Flooring 15 01-30-2012 01:46 PM
Installation of Granite Tile On Shower Walls Spacing Question. taras1 Building & Construction 2 08-04-2010 11:48 AM
Remove 3/4" oak floor before cement board and ceramic tile goes down?? 4just1don Flooring 8 10-31-2008 10:32 AM
