Tile Install Question - Flooring - DIY Chatroom Home Improvement Forum
Old 04-28-2008, 01:47 PM   #1
Question
I have a question about how pricing is done on floor tile. Let's say that the room is 176 sq. ft. - basic rectagular room, all tiles equal size (18X18), standard tile pattern. When you add 10%, you get roughly 200 sq. ft. for materials. So here's my question:
Does the installer typically charge their cost per sq. ft. times the actual installed area of 176 sq. ft., or do they charge times the 200 sq. ft. area?
TIA
Steve
Phostenix is offline   Reply With Quote
Old 04-28-2008, 02:22 PM   #2
Oldguy
Rehabber's Avatar
Any contractor will charge his estimated material costs, his various overhead expenses (transportation, equipment upkeep, insurance, permits, employee expenses, etc.) plus his time and a reasonable profit so he can make a decent living and stay in business. Exactly how he figures this will vary by each contractor. Don't stress how he charge, just what the total job will cost and the quality of work you will recieve -- The cheapest is usually the worst-- "If you want first quality oats, be prepared to pay for them-- If you can be satisfied by oats that have been through the horse once, they are a little cheaper"
If you think you can, or if you think you can't, you're probably right.
ASE certified master auto tech, Retired.
Rehabber is offline   Reply With Quote
Old 04-28-2008, 03:39 PM   #3
So, do installers typically charge by the measured sq. footage or by the +10%?
Old 04-28-2008, 05:46 PM   #4
If they would charge $40.00 sq.ft, they'd add the 10% there, charging 44.00 per sq. ft. and lose the loss there. But then, if the salesperson sits there and adds another 10% on top of that, and tells you that's for calculated loss, and you go for it, that's salesmenship.
LawnGuyLandSparky is offline   Reply With Quote
Old 04-28-2008, 07:43 PM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
You handle it, you charge for it.
Old 04-29-2008, 12:55 PM   #6
Thanks everybody.
Old 04-29-2008, 02:23 PM   #7
ayeshaa's Avatar
You might want to work it out on this calculator at http://www.housetohome.co.uk/calculators
ayeshaa is offline   Reply With Quote
Tile installation question pjpjpjpj Carpentry 7 09-21-2008 12:29 PM
Tile laying question Profane Flooring 12 01-25-2008 11:28 PM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 04:31 PM
HELP! Tile flooring question Marsy Flooring 1 02-16-2007 10:22 PM
HELP! Question About Lousy Tile Setting Job... EricW Flooring 10 09-13-2006 08:02 PM
