Tile Height Versus Laminate - Flooring - DIY Chatroom Home Improvement Forum
Old 07-16-2011, 10:05 PM   #1
Question
Tile Height versus Laminate
Our bathroom had an extensive leak under the flooring. It has been fixed, but the sub-flooring had to be removed. We had laminate flooring, but would like to replace it with tile now that we must replace the floor anyway. We are concerned about the height difference between the old laminate and the new tile. How do we fix this?
Should we lay thinner sub-flooring? Will the difference be a problem at all?
The current laminate is level with the wood floors outside of the bathroom (which i know the tile to wood can be fixed with a threshold) but what about the toe kick under the counter?
Thanks for your help!
doedoe is offline   Reply With Quote
Old 07-30-2011, 11:43 AM   #2
It's no problem what-so-ever. You just need a hard surface reducer. That is used when two hard surfaces that meet are unlevel. You would use the t-molding when the two hard surfaces are even.
ttr13r is offline   Reply With Quote
Old 07-30-2011, 12:02 PM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Why would that be a problem? How big are your toes ?
XXX
Tags
bathroom , flooring , sub-floor , tile
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 06:10 PM
Matching Tile Floor Height Bentley S. Flooring 0 01-11-2011 03:31 AM
asbestos tile under laminate? bubbler Flooring 1 12-05-2010 01:53 PM
Cement board and tile over laminate??? williaslw Remodeling 3 10-17-2008 07:19 AM
Counter top plastic laminate Gerry Kiernan Interior Decorating 4 10-13-2008 10:44 AM
