Tile To Hardwood Transition Question - Flooring - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 2 Post By MTN REMODEL LLC
Old 01-03-2017, 08:51 PM   #1
Rewards Points: 68
tile to hardwood transition question
p { margin-bottom: 0.25cm; line-height: 120%; }a:link { } So here's the problem.
I am trying to replace some crummy old thin what do you call them even? - fake linoleum stickdown floor tiles? With ceramic.
The problemm is making the transition to the adjacent wood floor as neatly as possible.
The gap between the subfloor and the hardwood is about 17mm (about 7/16)
so there was 1/2 plywood over that subfloor, presumably to build it up.
The new tiles plus the mesh lath measures 10mm. Add the mortar (1mm) and I will be about 11mm height.
Had I installed the new tile and mesh over the 1/2 plywood, I would have been... well proud of the hardwood, like 5mm / 3/16 high.
Having removed the plywood, I am now about the same low.
So, what do I do?
Wife says ignore it and slap in some filler piece, like quarter round.
That bugs me.
So, do I lay NEW plywood down to build up the difference?
3/16 ? does that even exist?
Otherwise, what are my reasonable options?
Ideally I would like to lay the new tile and presto! Have it all flush and level (but given I am also a novice tiler, what are the odds of that?)
Peter
pjstock is offline   Reply With Quote
Old 01-03-2017, 09:25 PM   #2
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 2,834
Re: tile to hardwood transition question
Can you just cut a transition.... it is difficult to marry 2 floors exactly to each other...
This on just happens to be drying right now....
tile to hardwood transition question-diy-1-.jpg   tile to hardwood transition question-diy-3-.jpg
CosmicMiami and ZZZZZ like this.
MTN REMODEL LLC is offline   Reply With Quote
Old 01-04-2017, 07:45 AM   #3
Rewards Points: 260
You could also get a regular piece of T transition and remove 3/16" (the height difference between the finished hardwood and tile) from the underside of the transition that will sit on the hardwood....this will leave the transition level. You would need some tools e.g. table saw or router to do this.
JIMMIEM is offline   Reply With Quote
Old 01-04-2017, 08:56 AM   #4
Rewards Points: 205
I am by no means an expert on this having only done a similar project with laminate flooring married against tile. I glued the last strip to the floor adjacent to the tile and it looked great. I don't like the transition tees. There's nothing like a nice smooth, continuous transition.
Couple of questions. Is that new plywood you put down (shown in the pic) or is it existing? What is under that plywood? How big of an area are we talking about?
My initial thought was to replace your underlayment with a thicker plywood. I've also seen tile setters use a mixture of mortar and quikrete to build up areas that are low. It's not easy. Probably not something for a novice.
The transition idea that MTN showed looks like a good solution. I'll keep that in mind as I will be doing a flooring project soon (depending on how much the wifey bugs me!). I'm dreading it because of this very reason, a couple offsets in the existing flooring. LOL
CosmicMiami is offline   Reply With Quote
Old 01-04-2017, 08:50 PM   #5
Rewards Points: 68
this space is pretty small, just an entranceway measuring 7ft x 6ft so... 43 sqft.
in the picture that is old plywood.
under the plywood? are the joists I think and just an empty basement area.
IN the end I opted to lay down new sheets of mahogany underlay which is exactly 3/16" and so brings everything up basically level.
I agree that butting the tile right up to the hardwood looks like a nice clean transition. (I only got the plywood and the mesh installed today. scratch coat and tiles are for another day)
I'll let you all know how it goes.
thanks for your attention.
Peter
Old 01-04-2017, 08:58 PM   #6
Rewards Points: 68
that's a great tip.
though I won't use it for this job.
question. is that a stock piece of beveled wood or did you make it custom?
I guess with a table saw (which I don't have) it wouldn't be that hard to trim down a piece to suit.
Old 01-04-2017, 10:43 PM   #7
ZZZZZ's Avatar
Rewards Points: 2,202
Just be sure to use some flexible caulk, not grout, for the joint between the tile and the hardwood floor. There needs to be a little bit of give and take between the two to allow for expansion/contraction of the wood.
Just my 7 cents (2 cents after taxes and inflation).
ZZZZZ is offline   Reply With Quote
Old 01-05-2017, 10:18 AM   #8
Originally Posted by pjstock View Post
that's a great tip.
PJ.... That's just 3/4 oak board (with 1/4 hardboard glued to the underside for a buildup) ripped/sanded.
Yes... Easy with a table saw... really difficult without.
Actually, we wanted a transition/break... as, if you look closely, the tiles do not match exactly and the entry is 20" and the laundry is 18".
I find it easier in most cases to just make/cut/stain-to-my-color a transition, rather than go and try to find one.
Good luck
Tile Repair Question SMLWinds Tiling, ceramics, marble 3 03-29-2015 06:41 PM
Bathroom tile to hallway hardwood transition iceclimber2001 Tiling, ceramics, marble 8 01-13-2013 09:48 PM
Tile transition to hardwood floor (1" lower) gambit Flooring 2 04-02-2012 03:20 PM
Laying tile over hardwood stairs steps Flt_Simulation Flooring 12 01-06-2011 08:33 PM
hardwood to ceramic no transition strip alaus24 Flooring 2 11-30-2010 09:53 AM
