Tile To Hardwood - Flooring - DIY Chatroom Home Improvement Forum
Old 01-17-2013, 06:14 AM   #1
Tile to Hardwood
I am in the process of removating a kitchen. I will be removing the ceramic tile and installing a nailed down hardwood floor. After I get the tile up how do I remove the thin set that remains on the sub floor? Currently there is 1/2" plywood over 5/8" plywood. I had installed the tile floor 20 years ago. I had to replace the 1/2" in some areas where I removed an existing tile area and I know that I glued and screwed the 1/2" in those areas, so removal of the 1/2" may be next to impossible.
Any suggestions on how to remove the thinset w/o having to remove the subfloor?
GMC@CJ is offline   Reply With Quote
Old 01-17-2013, 06:38 AM   #2
DIY staff
Rewards Points: 7,174
Angle grinder with a diamond cup works well---you will want to use a dust cowl and a vacume cleaner ---
Old 01-17-2013, 06:52 AM   #3
Rewards Points: 4,796
Multitool with scraper blade might also work well - less dust. Same idea, more movement - Spyder blade on reciprocating saw.
jeffnc is offline   Reply With Quote
Hardwood 1/8 lower than tile schluter edging Pelican Flooring 4 05-05-2011 05:57 AM
Installing Hardwood Floor butting up to tile Macker Flooring 3 01-02-2011 03:21 PM
Hardwood transition to ceramic tile willyberger Flooring 5 08-09-2009 11:38 AM
Transition from hardwood to ceramic tile. tmbrink Flooring 1 03-09-2009 12:04 AM
glued tile to hardwood missmom65 Flooring 7 06-04-2008 11:19 PM
