-   -   Tile to Hardwood (http://www.diychatroom.com/f5/tile-hardwood-169356/)
GMC@CJ 01-17-2013 07:14 AM
Tile to Hardwood
I am in the process of removating a kitchen. I will be removing the ceramic tile and installing a nailed down hardwood floor. After I get the tile up how do I remove the thin set that remains on the sub floor? Currently there is 1/2" plywood over 5/8" plywood. I had installed the tile floor 20 years ago. I had to replace the 1/2" in some areas where I removed an existing tile area and I know that I glued and screwed the 1/2" in those areas, so removal of the 1/2" may be next to impossible.
Any suggestions on how to remove the thinset w/o having to remove the subfloor?
oh'mike 01-17-2013 07:38 AM
Angle grinder with a diamond cup works well---you will want to use a dust cowl and a vacume cleaner ---
jeffnc 01-17-2013 07:52 AM
Multitool with scraper blade might also work well - less dust. Same idea, more movement - Spyder blade on reciprocating saw.
