Tile Guys, What Would You Do? - Flooring - DIY Chatroom Home Improvement Forum
Old 05-02-2008, 08:44 PM   #1
Registered User
Termite's Avatar
Tile guys, what would you do?
I'm gutting my bathroom, and am tearing up the existing tile floor, which is about 12 years old or so.
Underneath the tile is a layer of 1/2" wonderboard on 1-1/8" subfloor.
The tiles are popping up reasonably easily, but pretty much all of the thinset mortar has stayed put, firmly bonded to the wonderboard. In some locations, the top surface of the wonderboard has popped up with the tile and the thinset, exposing the mesh of the wonderboard.
Here's where the problem is...
The guy that remodeled this bathroom when my dad owned the house didn't do much right, but he put screws every 3" in a grid pattern through that wonderboard into the floor. There is absolutely no way I can get that wonderboard up (because the hundreds of screws are covered up and/or the heads are full of thinset), and it is in pretty decent shape overall.
I'm thinking that I could easily float a layer of thinset or some sort of mortar over the top of the wonderboard and grooved thinset to yield a smooth surface to apply the new tile to. I certainly don't want to try to mount the tile given the current condition of the surface.
What do you all think of that idea, and what mortar or thinset would you use?
Old 05-02-2008, 08:59 PM   #2
K&B Remodeler/Tile Guy
angus242's Avatar
You could use a self leveling compound (SLC). Just look at whatever your local supplier would carry to make sure it will fit your application.
It will cover the current flooring and level it at the same time. Wait a few hours and start tiling normally.
angus242 is offline   Reply With Quote
Old 05-02-2008, 09:50 PM   #3
Registered User
Termite's Avatar
Not a bad idea...
Not too sure about availability as a bag mix though??? Is that available?
The only SLC I'm familiar with comes from batch plants and is used in big multifamily projects.
Old 05-02-2008, 09:58 PM   #4
angus242's Avatar
Not sure what's available in your area. I know HD carries Custom products. As far as I know, all the major manufacturers of thinset make an SLC, mapei, laticrete, etc.
http://www.custombuildingproducts.co...er=arc&lang=en
Old 05-02-2008, 11:13 PM   #5
Registered User
Termite's Avatar
Nice! Thanks Angus.
Old 05-03-2008, 08:22 PM   #6
I just finished a real bad one too, needed a couple days of hammer and large floor chisel to get that concrete board out, yep lots of screws.
Anyway, after the rebuild, it still needed a leveling in some spots but not a full blown self level.
I just used Henry UniPro 547 skimcoat around the edges and in a bad corner, worked great.
not self leveling but very workable stuff.
I put hardibacker on top of it, so maybe a little different than your situation, but the stuff sets up real solid, it might be good for you.
Finished tile floor and cabinet sets were right on.
jbhandyman is offline   Reply With Quote
Old 05-05-2008, 12:18 AM   #7
Anywhere you have a depth more than 1/4 inch where the board lifted up I would first patch with mortar and let set, self leveller is not intended to go any thicker, you would have to do multiple layers and let each dry and that's too much time, and since you need mortar anyways..... Then roll on an acrylic bonder & let dry, and then use a self leveller (and yes they sell single bags, one will do about 60 s/f at 1/4 thick, mix it EXACTLY as the bag says!!) once set, go ahead and tile away.
dochorn is offline   Reply With Quote
Old 05-05-2008, 12:21 AM   #8
angus242's Avatar
While that may be your preference, Custom's SLC is approved to 2" thickness. I wouldn't do that thick myself either but 1/4" is well within the specs.
Tile over Tile ?? Piney Flooring 17 02-06-2012 10:59 PM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 04:31 PM
Some questions about laying Tile? DiY_RooK Flooring 1 08-31-2007 10:35 PM
Subway tile installation bigboyjoel Flooring 3 08-02-2007 08:15 AM
Tile and laminate, or get rid of tile? kfoster Flooring 10 03-17-2006 03:14 PM
