Tile Grout... Sanded Or Unsanded - Flooring - DIY Chatroom Home Improvement Forum
Old 02-24-2011, 06:35 PM   #1
Rewards Points: 87
Tile grout... sanded or unsanded
Went to pick up some grout today, and I noticed they sell both sanded and unsanded versions.
What is the difference?
Im using 13" tiles, with 3/8" spacers and they will be in wet areas (shower, and counter top). Is there a perfered grout for this application?
phantasm72 is offline   Reply With Quote
Old 02-25-2011, 06:53 AM   #2
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
Sanded is stronger. It's usually used for floors the most. It gives better slip resistance and has more structural strength in larger joints. Unsanded gets into smaller joints better and leaves a smoother finish. Any joint over 3/16 I would use sanded.
poppameth is offline   Reply With Quote
Old 02-25-2011, 07:17 AM   #3
DIY staff
Rewards Points: 7,174
Read the label---unsanded is for gaps 1/8 or smaller---sanded is for larger gaps--You need sanded for this job.
Old 02-25-2011, 06:00 PM   #4
Rewards Points: 87
Yeah, i read the boxes, unsanded said good for 1/8 to 1/2 inch grout lines, sanded said for 1/8 to 1/2 inch plus grout lines. Since I fell in the less than 1/2" range, I was wondering if there was a difference for my use
Old 02-25-2011, 06:23 PM   #5
Handyman
Rewards Points: 512
You didn't specify what you are tiling but as mentioned before, sanded grout is stronger. Also, non-sanded is more like a gel, so if you choose to use this do smaller areas at a time. Unsanded grout is very difficult to clean if you let it set too long.
canadaclub is offline   Reply With Quote
Old 02-26-2011, 09:12 AM   #6
Rewards Points: 87
Its a benchtop for a bathroom counter, and the shower.
I assume, irregardless of type of grout used, that it should be sealed once cured.
Remove tile grout ninghai Flooring 6 06-06-2010 10:51 PM
Grout sealer on porcelain tile. sukhenkoi Tiling, ceramics, marble 5 04-28-2010 04:51 PM
Sanded or Unsanded Grout oguevarra Flooring 6 02-03-2010 04:05 PM
Should I seal my shower tile grout? Limit54 Tiling, ceramics, marble 23 12-13-2009 11:23 AM
Removing water stains for shower tile grout? acyate General DIY Discussions 2 08-07-2009 07:38 PM
