Tile Grout Cleaning And Sealing - Flooring - DIY Chatroom Home Improvement Forum
Old 02-17-2013, 06:26 PM   #1
Tile grout cleaning and sealing
I am renovating my bathroom. The tile is in good shape, but the original white grout is dark looking in spots. I would like to clean and seals the grout. The grout is the kind without sand. Does anyone have ideas on cleaning white grout? Any suggestions for sealing the grout once it is cleaned?
Rats is offline   Reply With Quote
Old 02-17-2013, 08:57 PM   #2
Get yourself a toothbrush and some bleach and alot of elbow grease. Keep rinsing the cleaned areas as you go along. If that doesn't clean it to your satisfaction you can also use a mixture of 2 chemicals that you can buy at thechemistrystore, sodium percarbonate and oxalic acid. Sodium percarbonate is pure oxy clean, straight up, and oxalic acid is used as a brightener.
rnack is offline   Reply With Quote
Old 02-18-2013, 02:28 PM   #3
tile cleaning
Thanks rnack. That sounds like lots of fun, but if it works it will be worth it. Fortunately, the bathroom is very small.
Old 02-18-2013, 06:35 PM   #4
good luck, let me know how it comes out.
Tags
grout , tile
Tile grout cleaning and sealing Rats Tiling, ceramics, marble 10 11-29-2014 01:34 AM
Cleaning grout lines/shower tile question Pawl Flooring 0 02-17-2012 03:03 AM
Tile grout color situation jay1028 General DIY Discussions 1 06-26-2010 05:57 AM
