Old 04-30-2008, 09:40 AM   #1
Tile-grout
I have problem with grout. just put in a new bathroom in basement have problems with the grout, the color is a earth color and when the grout dries it turns white on top layer. already tried cleaning it with a damp sponge no change. I have used a dremmel and taken off the top layer of grout where the white is and underneath it is the earth color. anyone have any ideas on why this is happening?
Linda
briones66 is offline   Reply With Quote
Old 04-30-2008, 10:33 AM   #2
Tileguy
Bud Cline's Avatar
Tile-grout
Yow!
You used too much water to clean the grout at original installation time and maybe allowed some water to stand on the grout to dry.
If/when you remove the grout to regrout you should remove the grout down 2/3's.
Cracking floor grout - Ceramic tile DeepDish Building & Construction 9 08-27-2008 10:51 PM
Tile discoloration by grout jngtexas Flooring 5 01-28-2008 08:30 PM
Do Tile setters seal grout? Yeti Flooring 2 10-24-2007 06:18 PM
Cracking floor grout - Ceramic tile DeepDish Flooring 9 03-03-2007 08:49 PM
Can you caulk over grout lines in a tile shower? Greg General Discussion 7 11-20-2006 06:20 PM
