Tile Gap - Flooring - DIY Chatroom Home Improvement Forum
Old 11-18-2012, 04:12 PM   #1
tile gap
Can I use Fixall for a gap between tile & floor tile before I put the grout in, is it watwr proof?
ronglo is offline   Reply With Quote
Old 11-18-2012, 04:25 PM   #2
Rewards Points: 12,822
Ok what's fixall? Go back and read you own post. Hard to figure out what the issue is from the post?
Old 11-18-2012, 04:59 PM   #3
JOATMON
ddawg16's Avatar
Rewards Points: 816
I know what "Fixall" is....but what is "&amp"?
Fixall is somewhat water proof....but give us a better description and maybe a pic or two and we might be able to give you a better answer.
Old 11-18-2012, 08:12 PM   #4
if it is where the floor tile meet the wall tile you do not want grout there, only caulk. if you use grout it will definitely crack because the floor and wall do not expand and contract at the same rate. changes of plane involving tile are always (well they aren't always caulked) but should be caulked. go into any home about a year old and most will have cracks in the corners of the tile shower because they were grouted instead of being caulked. use a color matched caulk that matches your grout. if it is where floor tile meet the wall you don't need anything, your base will cover the gap and the tile does need some room for expansion.
Solving discontinued tile issue timbo59 Flooring 14 10-03-2012 09:03 PM
Asbestos Removal, Porcelain Tile Installation jimbriam Flooring 15 01-30-2012 02:46 PM
Removing Tile Over Hardwood: Need Help With Kitchen/Bath Creelove Flooring 3 02-01-2011 07:03 AM
Laying Subfloor for New Bathroom Question rjschwar Kitchen & Bath Remodeling 3 06-25-2010 04:06 PM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 04:31 PM
