Tile On Front Porch - Flooring - DIY Chatroom Home Improvement Forum
Old 04-22-2009, 08:02 AM   #1
Rewards Points: 85
Tile on Front Porch
Is it OK to tile a front porch? I'm closing on my first house & I noticed that it had some sort of tile ripped off the front porch for whatever reason. I asked the builder to re-tile the front porch & just wanted to make sure that it was ok to do that.
PearlWhiteGT is offline   Reply With Quote
Old 04-22-2009, 09:24 AM   #2
Tileguy
JazMan's Avatar
Rewards Points: 422
If the conditions are right and the work is done correctly, yes fine.
Jaz
Old 04-22-2009, 10:23 AM   #3
Rewards Points: 85
Thanks!
Old 04-22-2009, 10:55 AM   #4
Tileguy
JazMan's Avatar
Rewards Points: 422
Go ahead? Go ahead with what? Using which type of tile, thinset etc. Is the slab slopped? Any cracks or expansion joints? Does it get direct sun? You going to use a membrane or go right over the slab? Do you want to re-do it again in a few years?
Jaz
Old 04-22-2009, 03:40 PM   #5
Rewards Points: 5,336
What's the front porch made out of? My brother has a wood porch with 2 1/4" T&G doug fir wood. No good for tile.
Ron
Old 04-22-2009, 04:17 PM   #6
Rewards Points: 85
Front porch is concrete with no cracks. It's about 8'x4' or so.
Old 04-24-2009, 06:08 AM   #7
Rewards Points: 85
Here is a couple of pics of the floor. I wanted to pick the color & style of the tile but the builder forgot & went ahead with his own choice. What do you guys think?
Old 04-24-2009, 01:34 PM   #8
47_47's Avatar
Rewards Points: 76
I like the color. How will the tile be when wet?
47_47 is online now   Reply With Quote
Old 04-24-2009, 01:43 PM   #9
Rewards Points: 85
It should pretty good. It's not slick at all.
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 06:10 PM
Front Cement Steps / Porch Leaking bschwarz Building & Construction 2 04-14-2009 10:46 PM
Adding new Front Porch, need opinions MeraleeCrowl Remodeling 1 11-05-2008 12:47 PM
Color opinion for front porch rails and pillars? Beth777 Painting 6 07-14-2008 11:14 AM
Cracked ledger board on front porch King_Doodle Building & Construction 20 06-03-2008 09:16 PM
