Tile In Front Of Fireplace With Carpet - New Addition - Flooring - DIY Chatroom Home Improvement Forum
Old 11-11-2011, 04:49 PM   #1
Tile in front of fireplace with carpet - new addition
Hello,
We just put on a new addition with a gas fireplace flush to the wall. I want to install two rows of tiles in front of the fireplace before the carpeting goes in. The floor is a concrete slab. The carpet guy mentioned that we should install an underlayment (I assume cement board) over the concrete about a 1/2 inch smaller than the overall surface of the tiles, I believe so the carpet can be tucked in under the tile. My wife talked to the guy, so I am not sure if this is all correct. Does this make sense? I would think that we should be flush, considering the grout will not cover the exposed edges of the tile. Is there a better/correct way to do this, prior to carpet being installed?
Thanks in advance.
midi77 is offline   Reply With Quote
Old 11-11-2011, 05:48 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 52
CBU should not be installed on concrete. The tile should be set in thinset.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
rusty baker is online now   Reply With Quote
The Following User Says Thank You to rusty baker For This Useful Post:
Floor Doc (11-11-2011)
Old 11-11-2011, 08:40 PM   #3
Tileguy
JazMan's Avatar
Rewards Points: 290
As Rusty said, you do not install concrete backer on concrete. Set the tiles with the proper thin set mortar and use this kind of edging. http://www.schluter.com/2171.aspx
Jaz
Old 11-12-2011, 12:29 AM   #4
Set tile directly on concrete with thinset mortar. I prefer a different schluter profile for tile to carpet www.schluter.com/1_4_reno_tk.aspx
plowboy is offline   Reply With Quote
carpet pad glued to asbestos tile hpygl Flooring 2 10-02-2011 11:50 PM
tile to carpet transition billyg Flooring 1 09-24-2011 12:09 AM
Devil in the Details: Molding, Stairs, and Tile to Carpet moodwaffle Flooring 4 04-04-2011 03:23 PM
Tile landing Carpet stair Transition Tmint Flooring 1 02-04-2011 05:35 AM
Transition from grouted vinyl tile to carpet MI-Roger Flooring 2 11-29-2009 01:55 PM
