Tile Flooring Over Heating Element - Flooring - DIY Chatroom Home Improvement Forum
Old 01-20-2009, 01:24 PM   #1
Woodchucker
Question
Tile flooring over heating element
I'm installing a tile floor in my bathroom. I would like to install in floor heating. The heating element will not go over the complete floor but the tile will cover most of it.
My question is; How do I ensure the the tile floor is even when there will be an uneven surface due to the under floor heating element? Do I just add more morture under the tiles without the heating element under it?
Woodchucker is offline   Reply With Quote
Old 01-20-2009, 05:55 PM   #2
Rewards Points: 5,336
Are we entertaining the use of electrical infloor heating? If this is the case, you can float the thinset into the unheated sections giving you a somewhat consistant base. Tile is a relative installation as each unit will float on the thinset surface. Even on a relatively flat surface there will be oportunities for the floor to be uneven. Such is the adventure of tile.
Ron
Old 01-20-2009, 06:47 PM   #3
Woodchucker
Talking
Tile
Ron,
Thanks for the advise. I have layed down tile before, but I never installed the in-floor heating mat before. It seems to be relativley easy.
Thanks again for replying.
Steve
Old 01-21-2009, 05:54 AM   #4
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
Best way to get an even surface is to embed the element in a Self Leveling compound. That isn't always possible though. It depend on how level your floor is to begin with, what the subfloor is made of, etc.
poppameth is offline   Reply With Quote
Old 01-21-2009, 11:14 AM   #5
Woodchucker
Thumbs up
Tile floor over heating element
Poppa,
I have decided to install a 1/4" cement backer board over the plywood flooring. I will install the heating mat on top of this and use extra mortar to assist in leveling the tiles that won't have the heating mat under them.
Thanks for replying.
Steve
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 06:10 PM
Proper Voltage for small Nichrome heating element. Dacr0n Electrical 8 01-19-2009 11:30 AM
Basement flooring. Tile? HuskySkull Flooring 1 08-10-2007 11:45 PM
Bathroom flooring (tile?) Nhrafan Flooring 30 06-11-2007 11:44 AM
HELP! Tile flooring question Marsy Flooring 1 02-16-2007 09:22 PM
