Tile Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 09-21-2011, 05:19 PM   #1
Tile flooring
Six year old laminate floor ruined by water. Now I want to go with tile.I can't use existing plywood under layment to wet and warped. There is diagonal subfloor under it. How should I begin? Thanks Granpa
Granpa is offline   Reply With Quote
Old 09-21-2011, 06:09 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Six year old laminate floor was ruined by water. Now I want to go with tile.I can't use the existing plywood underlayment because it is too wet and warped. There is diagonal subfloor under it. How should I begin? Thanks Grandpa
Okay...if the above modifications are correct please say so and we can start over.
Old 09-21-2011, 09:37 PM   #3
The modifications are correct. Thanks for the english leson.
Old 09-22-2011, 12:58 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Obviously the warped ply must be removed. At that point if it was me I would go back with fresh ply not less than 3/8". Anything you do after that with laminate will then work out.
The modifications are correct. Thanks for the english lesson.
No "english lesson" intended, just trying to make things a little more understandable.
The Following User Says Thank You to Bud Cline For This Useful Post:
Granpa (09-23-2011)
Changing Kitchen Flooring from tile to Hardwood? Regarding taking cabinets up? doodleb1973 Flooring 3 07-27-2011 05:25 AM
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 06:10 PM
click lock wood flooring and tile guessingo Flooring 3 09-15-2010 10:56 PM
adhesive for tile flooring? AndrewH Flooring 13 11-26-2007 07:58 AM
Tile flooring question Jen4463 Flooring 2 10-15-2007 01:19 PM
