Old 08-23-2006, 02:24 AM   #1
Tile floor or wall first?
I recently purchased my house (so I am broke and cant hire someone)and have come across a problem in the upstairs bathroom. This bathroom was all original from the mid 60's and over time, the plaster wall behind the tile in the shower area has gotten wet and gave out. Just recently the soap tray fell off and exposed a large hole. I have taken the tile off the walls and ripped out the damaged wall. We have decided to remodel the rest of the room while I am this far in.
I am going to be installing a new tile floor as well as installing tile around the walls in the room.
Should I work from the ground up in this situation and install the flooring before moving on to the walls?
Thanks in advance for any information.
LX8850 is offline   Reply With Quote
Old 08-23-2006, 03:19 AM   #2
Oldguy
Rehabber's Avatar
I always do the wall first, Seems to me that the edges come out better
If you think you can, or if you think you can't, you're probably right.
ASE certified master auto tech, Retired.
Rehabber is offline   Reply With Quote
Old 08-23-2006, 09:57 PM   #3
Middle aged floor guy
Donedat's Avatar
Tear it all out in one big sweep. That way you can inspect and repair the all the damage in step 2 of your remodel.
Donedat is offline   Reply With Quote
Old 08-30-2006, 01:01 AM   #4
Floorwizard's Avatar
Floor first.
Unless you can perfect EXACTLY how high the tile and thinset and underlay is going to be.
Floorwizard is offline   Reply With Quote
Tile over Tile ?? Piney Flooring 17 02-06-2012 10:59 PM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 04:31 PM
Subway tile installation bigboyjoel Flooring 3 08-02-2007 08:15 AM
Tile roof questions/repairs help please xoroniox Roofing/Siding 3 12-17-2006 03:02 PM
Tile and laminate, or get rid of tile? kfoster Flooring 10 03-17-2006 03:14 PM
