Old 01-07-2013, 12:55 PM   #1
Tile Floor / Electrical Radiant Heat / Mortar Not Setting
I installed a tile floor in a lower level bathroom. The tile is 6" * 24". I purchased the tile and the "premium mortar" from Menards. I laid the electric matting, mortared over the mat. For areas where I mortared over the mat - had good success with the tiles setting. For areas where there was no matting, and required a thicker mortar base, the mortar is not hardening. It's about 3/4" thick. I have placed a heater in the bathroom to try to warm the space.
My question is: will this mortar eventually set? or do i need to remove and redo with powder mortar that can set in cold spaces and not have as much water content?
aaldrich55443 is offline   Reply With Quote
Old 01-07-2013, 09:22 PM   #2
Tileguy
JazMan's Avatar
Something tells me you did not use real mortar, but something pre-mixed. How about you tell us what mortar you used?
Jaz
Tile 4 You LLC Troy, MI
KERDI Shower Specialist ... DITRA Installs ... Product-Method suitability consultation. I have NEVER made a mistake, I thought I did once...........but I was wrong! - PRODUCTS ADVERTISED WITHIN MY POST ARE NOT ENDORSED BY ME!
Old 01-07-2013, 11:02 PM   #3
http://www.menards.com/main/flooring...260-c-6586.htm
This is the link to the product that used ... Thanks for your help. By the way, I laid this on a concrete basement floor in Minnesota ( it's a little cold at this time of the year)
Old 01-07-2013, 11:46 PM   #4
Tileguy
JazMan's Avatar
There's only one good thing about that product for what you used it for. The empty bucket.
Jaz
Old 01-08-2013, 06:50 AM   #5
Super Moderator
You chose the wrong product-----You need a powdered modified thinset----
That product requires air to dry----no air under a tile----You may have installed the mat incorrectly also---What did the manufacturer ask for as a setting material----
oh'mike is online now   Reply With Quote
Old 01-08-2013, 08:35 AM   #6
Looks like a scraper night ...! Complete bummer. I chose this product to save me some time - looks like it's only costing me time now. As for the heat matting, I thought I followed the directions - laid flat on the floor, taped / glued where I was suppose to do so, and applied the "mortar" which obviously isn't mortar over the mat. I hope I didn't lose the mat in the process - the darn thing isn't cheap. I'll let you know how this shakes out.
Can I use tile adhesive over old mortar to fix loose tiles? JFERTICH Flooring 1 10-13-2012 11:20 PM
replacing the tile over radiant heat cet Flooring 1 08-27-2011 08:26 AM
Radiant heat manifold configuration red-wolf Plumbing 13 01-25-2011 02:03 PM
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 07:10 PM
Radiant floor heat question. ingeborgdot Remodeling 6 03-23-2010 01:05 PM
