-   -   Tile Floor / Electrical Radiant Heat / Mortar Not Setting (http://www.diychatroom.com/f5/tile-floor-electrical-radiant-heat-mortar-not-setting-168477/)
aaldrich55443 01-07-2013 11:55 AM
I installed a tile floor in a lower level bathroom. The tile is 6" * 24". I purchased the tile and the "premium mortar" from Menards. I laid the electric matting, mortared over the mat. For areas where I mortared over the mat - had good success with the tiles setting. For areas where there was no matting, and required a thicker mortar base, the mortar is not hardening. It's about 3/4" thick. I have placed a heater in the bathroom to try to warm the space.
My question is: will this mortar eventually set? or do i need to remove and redo with powder mortar that can set in cold spaces and not have as much water content?
JazMan 01-07-2013 08:22 PM
Something tells me you did not use real mortar, but something pre-mixed. How about you tell us what mortar you used?
Jaz
aaldrich55443 01-07-2013 10:02 PM
http://www.menards.com/main/flooring...260-c-6586.htm
This is the link to the product that used ... Thanks for your help. By the way, I laid this on a concrete basement floor in Minnesota ( it's a little cold at this time of the year)
JazMan 01-07-2013 10:46 PM
There's only one good thing about that product for what you used it for. The empty bucket.
Jaz
oh'mike 01-08-2013 05:50 AM
You chose the wrong product-----You need a powdered modified thinset----
That product requires air to dry----no air under a tile----You may have installed the mat incorrectly also---What did the manufacturer ask for as a setting material----
aaldrich55443 01-08-2013 07:35 AM
Looks like a scraper night ...! Complete bummer. I chose this product to save me some time - looks like it's only costing me time now. As for the heat matting, I thought I followed the directions - laid flat on the floor, taped / glued where I was suppose to do so, and applied the "mortar" which obviously isn't mortar over the mat. I hope I didn't lose the mat in the process - the darn thing isn't cheap. I'll let you know how this shakes out.
