Tile Floor On Concrete - Flooring - DIY Chatroom Home Improvement Forum
Old 05-22-2007, 02:57 PM   #1
Tile Floor on Concrete
I would like to lay a cermamic slate tile floor in our bathrooms. If our sub floor is concrete do I need to install backer board? Do I need to level the subfloor?
trout_baller is offline   Reply With Quote
Old 05-22-2007, 07:15 PM   #2
Ceramic or Slate, which is it?, no backerboards over concrete, the floor has to be flat, is it?, any cracks, paint or sealers on it?
R&D Tile is offline   Reply With Quote
Old 05-22-2007, 10:42 PM   #3
Floorwizard's Avatar
it would be nice to see an anti fracture membrane of some sort used first before install of the tile.
Floorwizard is offline   Reply With Quote
Old 05-24-2007, 11:06 AM   #4
what is the going rate
for vct tile labor glue and tile
jpresley51 is offline   Reply With Quote
Old 05-24-2007, 06:07 PM   #5
Tileguy
JazMan's Avatar
Rewards Points: 228
Presley,
You didn't think anyone could possibly answer that question....did you?
Anyway, you should start your own thread.
Jaz
Old 05-27-2007, 11:10 PM   #6
shane
Send a message via Yahoo to artisticstoneworks.biz
no hardie backer would be used because you dont have hardwood flooring
i would use a motified thenset to help for bonding to the concreate if you have any cracks use flex guard or anti fracture membrane like hydroguard 9235 or flex guard
but the question is are you using slate if so you might have to wetset the floor "meaning float as you set" because slate is not the same gage thicker and thiner unless you spend alot for it to be gaged which is rare. most people dont
artisticstoneworks.biz is offline   Reply With Quote
Old 05-27-2007, 11:12 PM   #7
shane
i dont think you read the question clearly
Tile over Tile ?? Piney Flooring 17 02-06-2012 10:59 PM
tile over exterior concrete? BlueMoonBean Flooring 6 11-18-2008 02:55 PM
Concrete basement slab + Radiant + Tile MageMinds Flooring 4 08-21-2007 01:52 PM
Pulling up tile and laying bamboo on concrete kdhughes Flooring 2 07-20-2007 12:11 AM
Tile on concrete slab, ground level - bamboo? IvoryRing Flooring 2 06-28-2006 09:52 AM
