Tile Floor In Bathroom - Flooring - DIY Chatroom Home Improvement Forum
Old 03-24-2007, 10:14 PM   #1
Lehigh Valley PA
Tile floor in bathroom
I'm getting ready to install a tile floor in the bathroom with 12" X 12" tiles.
What grout spacing is ideal for this?
What mortar trowel (groove spacing and depth) should be used?
The dimensions of the room are: 5.5' X 6.5' so it's not real big of an area.
It will be over a slab foundation if that helps at all.
There is one small crack in the floor, of course right in the middle of the floor.
Should I try and do anything with this?
(this is of course a close up, it's not that big. It's also still level between the two sides as far as I can tell.
Also wanted to ask about the grout spacing and depth of thinset for wall tiles... 6"X6"
I was thinking of 3/16, would that be okay for the grout
Nhrafan is offline   Reply With Quote
Old 03-24-2007, 11:09 PM   #2
jproffer's Avatar
Rewards Points: 706
I use a 1/4 x 1/4 notch trowel for 12 x 12 on a floor. Wouldn't go quite that big for 6 x 6, so yea 3/16 x 3/16 should be ok.
jproffer is offline   Reply With Quote
Old 03-27-2007, 08:43 AM   #3
zel
Rewards Points: 150
Send a message via AIM to zel
I could be wrong, but:
1. grout spacing is a matter of personal preferance
2. the trowel spacing sets the thinset depth, to a point. IE-if you use a 1/4x1/4 you should end up with a 1/8 layer of thinset when the tiles are compressed?
3. Maybe adding the flexible additive would help prevent a crack on the tiles on the floor?
zel is offline   Reply With Quote
Old 03-27-2007, 11:17 AM   #4
Floorwizard's Avatar
a crack isolation membrane is needed first before tile install.
like redguard.
Floorwizard is offline   Reply With Quote
Old 03-27-2007, 11:39 AM   #5
use ditel... you can't beat this guy with anything else... cost you a bit more.. but you will be gurantee to be a success installation...
I said this from my experience....
KUIPORNG is offline   Reply With Quote
Old 03-28-2007, 09:51 AM   #6
Tile and Paint contractor
kui****g, do you mean DITRA?
that would work well in situation
trowel thinset then roll Ditra
install tile over underlayment
Id use a 3/8" trowel for 12" floor tile with a 3/16" grout gap
and 1/4" trowel for 6" wall tile and maintain the 3/16" grout gap up the walls
Take the time to snap reference lines
Measure a few times to see what your left with against tub, against walls, afront the doorway, etc. (no little itty bitty pieces)
Matt | tile contractor
Charlotte, NC
MattCoops is offline   Reply With Quote
Bathroom flooring (tile?) Nhrafan Flooring 30 06-11-2007 12:44 PM
Approach to demo bathroom ceramic tile floor for remodel corky Flooring 3 01-29-2007 10:59 AM
bathroom floor tile job advice needed dbrew Flooring 14 01-23-2007 08:03 PM
Getting ready to tile bathroom floor, question J187 Flooring 4 06-06-2006 01:31 PM
