Tile Flexing - Flooring - DIY Chatroom Home Improvement Forum
Old 02-21-2007, 08:06 PM   #1
Question
Tile Flexing
I just finished tiling my bathroom. It looks very good but when I get on my hands and knees to feel for smoothness I put pressure on the tile surface and the tile flexes a bit. Almost like the thin set isn't completely dry. Is this normal? Or am I screwed?
nsb318 is offline   Reply With Quote
Old 02-22-2007, 12:01 PM   #2
HJ1
tile man
What kinda thinset was this? Is it that premixed crap that comes in a bucket, or was this bagged thinset that you mixed yourself? When you say just finished, just finished when, did you let it set for 24 hours before walking on it?
HJ1 is offline   Reply With Quote
Old 02-22-2007, 01:52 PM   #3
Rewards Points: 150
I had this happen after completing my kitchen floor and the culprit was one tile that did not adhere properly. I used a dremel to remove the grout, chiseled out the remaining mortar and re-set the tile. It worked fine, but when I went to redo the grout, I tried to feather the grout over the existing grount lines. This caused the feathered areas to be a lighter color than the rest of the grout, so watch out for that. Otherwise it worked fine.
billinak is offline   Reply With Quote
Old 02-22-2007, 03:20 PM   #4
It shouldn't move after 24 hrs., if so, remove it, not sure like said above how this job was done and with what products, that would help.
Oh, and tiles don't flex.
R&D Tile is offline   Reply With Quote
Old 02-24-2007, 01:44 PM   #5
Tileguy
JazMan's Avatar
Rewards Points: 388
This problem is a continuation of this thread; Difficulty removing grout ?????????
318 used pre-mixed junk......ah..ah...thinset and grout and so these problems. But he already knew that a day or so before he started this thread.
Jaz
Tile over Tile ?? Piney Flooring 17 02-06-2012 09:59 PM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 03:31 PM
HELP! Tile flooring question Marsy Flooring 1 02-16-2007 09:22 PM
Tile roof questions/repairs help please xoroniox Roofing/Siding 3 12-17-2006 02:02 PM
Tile and laminate, or get rid of tile? kfoster Flooring 10 03-17-2006 02:14 PM
