Tile First Or Cupboards First??? - Flooring - DIY Chatroom Home Improvement Forum
Old 04-19-2010, 07:03 AM   #1
Tile first or cupboards first???
We are remodeling and I was wondering what everyone thinks the proper order should be when installing a tile floor and new cupboards.
We will be gutting the kitchen and taking up our wood floor to put in tile. Under the tile I will have electric radiant heat and ditra. Should I have all the put in first or have the cupboards put in first and then the tile? Thanks.
ingeborgdot is offline   Reply With Quote
Old 04-22-2010, 01:58 PM   #2
We generally recommend installing under the cabinets, if not entirely under then at least under the perimeter. The problem with installing the tile around the cabinets is that it never looks as good.
The only disadvantage of installing tile under the cabinets is the added height.
rcuerrier is offline   Reply With Quote
Old 04-22-2010, 02:05 PM   #3
What happens if a tile breaks and you have to replace the tile but a bunch of it is under the cabinet?
Old 04-22-2010, 02:08 PM   #4
Newbie Bill
Rewards Points: 522
What do you do in a few years when you want to replace the floor, but not the cabinets?
This question has been asked many times and everyone has a different opinion.
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is online now   Reply With Quote
The Following User Says Thank You to drtbk4ever For This Useful Post:
rcuerrier (04-22-2010)
Old 04-22-2010, 02:20 PM   #5
We've done it, it's a nightmare and isn't a very pleasant rip out, but can be done.
At the end of the day it's the customers decision but I do my best to help them recognize that a tile floor should be approached as a permanent floor covering option that isn't easy or inexpensive to replace. Typically speaking when a tile floor is installed over ditra the installed price will be upwards of $15 a foot. That's an expensive floor to replace down the road.
Like you said though, it's a question that will be asked many times and everyone will have a different opinion.
The Following User Says Thank You to rcuerrier For This Useful Post:
drtbk4ever (04-22-2010)
Old 04-22-2010, 02:25 PM   #6
I guess I have to ask why it would not look as good if you put it in later, after the cabinets? Sure, there would be cuts but if they are done right the toe kick should cover them shouldn't they?
Old 04-22-2010, 02:28 PM   #7
Then you'll have to chip it out carefully, we've done it and it isn't easy, but can be done.
If you install your tile properly, to Schluter's specifications (i.e. modified thinset if you're bonding the Ditra to plywood, and unmodified to bond the tile to the Ditra) and use the correct trowel size, and make sure that your substrate is suitable for tile installation then you should have no issues with "cracking" tiles.
In my experience almost any tile installed properly in a residential setting will be extremely difficult to break.
Old 04-22-2010, 02:30 PM   #8
Sounds like you may have decided what you'll do
If you've got a good wet saw and do a good job cutting your tile it will look fine. I've always preferred seeing the tile go under the cabinets, but that's just one man's opinion
Old 04-22-2010, 02:48 PM   #9
I think I am going to have a professional do this one.
Tile over Tile ?? Piney Flooring 17 02-06-2012 09:59 PM
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 06:10 PM
Trimming installed tile with tile blade in normal circular saw? jdraughn Tools 5 12-13-2009 09:07 PM
Some questions about laying Tile? DiY_RooK Flooring 1 08-31-2007 09:35 PM
Tile and laminate, or get rid of tile? kfoster Flooring 10 03-17-2006 02:14 PM
