Tile On Exposed Edge (floor) - Flooring - DIY Chatroom Home Improvement Forum
Old 04-19-2013, 03:39 PM   #1
Rewards Points: 640
Tile on exposed edge (floor)
I am tiling the entrance in our basement, its an area about 9ft deep and 20ft long, the 20ft long side that is not against an exterior wall will transition to carpet and continue on
Is it better to put whole uncut tiles against that edge and tile against that as a reference point, or still go for the exact center of the room? as the starting point and cut these tiles to be equal size to the other side that is against a wall?
House Information: Build 1996, 1500 sq ft basement, 1500 sq ft 1st floor, 800 sq ft 2nd floor, 560 sq ft unfinished attic space on 2nd floor. Insulation: Attic blown fiberglass, walls R-19, Basement R-19. HVAC: Trane xc95m fully modulating furnace, single zone, Trane XL20i commiunicating AC unit, TCONT900 Communicating thermostat.
BlueBSH is offline   Reply With Quote
Old 04-19-2013, 06:27 PM   #2
Rewards Points: 12,796
Those tile are going to show the most, I'd use whole tiles there and use the cut tiles on the outside edges.
problem with a simple floor tile design wengang1 Flooring 8 03-24-2013 03:23 PM
Granite Floor Tile Help trophywalleye Flooring 4 01-09-2011 04:29 PM
Floor Joists for Tile Floor in the Kitchen Dutchman80 Building & Construction 1 11-23-2010 04:22 PM
Mud floor for tile sub floor dell85583 Flooring 1 10-27-2010 08:54 AM
Concrete floor prep for ceramic tile tpanc13 Flooring 39 06-22-2010 09:50 PM
