Tile For Entryways A Necessity? - Flooring - DIY Chatroom Home Improvement Forum
Old 06-20-2013, 09:50 AM   #1
Rewards Points: 87
Tile for entryways a necessity?
Hi all. I'm about to redo my flooring next week and I had a quick question. I'm putting in hickory hardwood. Should I put the hardwood all the way up to the front and back door? Or should I tile up a little 4x4' square area just inside both doorways? Currently, this is how the house is set up. But the tile is old and outdated looking.
So I was just going to smash that tile and let the flooring guys just lay the hardwood right over it. But would that make a wear spot too quickly in the wood? Would I be better off to leave the tile?
Bennylava is offline   Reply With Quote
Old 06-20-2013, 01:25 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 142
I've done it both ways, don't see much difference in wear, unless you are using laminate. It won't last in an entryway. My house was built in 1908, still has the original oak floors everywhere but the bath and kitchen. Looks fine in the entrys.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
rusty baker is online now   Reply With Quote
Old 06-20-2013, 02:22 PM   #3
JOATMON
ddawg16's Avatar
Rewards Points: 1,956
This is an example of why it helps to put your location in your profile.
If you live in California, AZ, NM.....no difference.....
If you live in the northern states that see a lot of rain and snow....tile is a good choice....water is not going to ruin it.
Old 06-20-2013, 03:19 PM   #4
Rewards Points: 142
We get a lot of rain and snow in Missouri.
Old 06-20-2013, 05:07 PM   #5
MarginallyQualified
Rewards Points: 2,464
4x4 sounds too small.
Stand there with wet boots and a wet umbrella. See how much floor gets wet. Add some sort of impervious floring material. Personally, tile would be my last choice.
Old 06-20-2013, 05:39 PM   #6
Rewards Points: 87
Ok I live in TX. We get a medium amount of rain in my area. The DFW area. But no snow and not really any mud.
Old 06-20-2013, 05:58 PM   #7
MarginallyQualified
Does the front entry have a porch or vestibule to serve the purpose?
Old 06-20-2013, 07:53 PM   #8
DIY staff
Rewards Points: 7,174
I'll bet you will be fine without an entry pad----My guess is you have a low impact house hold---or you would not have asked---
I have 'landing pads' at two entrances, but were we have snow,so wet melting boots are an issue---
Old 06-21-2013, 12:07 AM   #9
Rewards Points: 87
Yeah no kids, and the porches could serve I suppose. Thanks for the help all!
Old 06-21-2013, 12:45 AM   #10
JOATMON
ddawg16's Avatar
Medium amount of rain? Yea, right. I used to live there (graduated from LD Bell)
What you call 'medium' is a turd floater elsewhere....
I've seen it rain so hard that you couldn't see 10' away.
You get one snow a year....but 2-3 ice storms.....typical weather....65 on Christmas day....10 deg Jan 2nd....
Old 06-21-2013, 07:38 AM   #11
Bill Kearney
Rewards Points: 1,174
Another thing to consider is the flooring height relative to the doors. If your doors are already sweeping very close to the flooring then you might want to keep a tiled area at the entrance. otherwise you wouldn't be able to put down a rug or mat during the times when you want to protect the wood from wet traffic.
wkearney99 is offline   Reply With Quote
Solving discontinued tile issue timbo59 Flooring 14 10-03-2012 08:03 PM
Asbestos Removal, Porcelain Tile Installation jimbriam Flooring 15 01-30-2012 01:46 PM
Removing Tile Over Hardwood: Need Help With Kitchen/Bath Creelove Flooring 3 02-01-2011 06:03 AM
Laying Subfloor for New Bathroom Question rjschwar Kitchen & Bath Remodeling 3 06-25-2010 03:06 PM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 03:31 PM
