Tile Cutting Saw - Flooring - DIY Chatroom Home Improvement Forum
Old 10-06-2011, 11:56 PM   #1
Question
Tile cutting saw
I need to rent a saw to cut some floor tiles 12"x12". Will i also be able to cut 3"x6" subway tiles with the same saw? There was a few saws for rent at home depot but i didn't know which one to get? The guys who work there don't seem to know any better either. lol / thx
EelectricP is offline   Reply With Quote
Old 10-07-2011, 11:01 AM   #2
Question
FYI,
The 12x12 is ceramic and 3x6 is the white subway tile from Home Depot.
12x12 about 15-20 floor diagonal cuts and 3x6 about 40-50 shower end pieces.
All the tiles that did not need cuts have already been installed.
I plan to purchase new blade for rental saw.
Can i rent one saw for both these tiles? thx
Old 10-07-2011, 11:21 AM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
They are both "ceramic" tiles.
Are the 12X12's porcelain tiles?
If porcelain (which is also ceramic) they will be somewhat harder than regular ceramic floor tiles. Porcelain requires a substantial blade but anything that will cut porcelain will easily cut the lessor subway tiles.
It would be nice to know the brand name and blade size of the rental saws you are asking about. Can't begin to tell you what to expect without knowing what machines are available to you.
Old 10-07-2011, 12:03 PM   #4
A Little Of Everything
Rewards Points: 1,362
"The guys who work there don't seem to know any better either..." Yeah, imagine that! The HD closest to me rents out about a gazillion different tools, which is great. But one of the guys who works in the tool rental area is named Ian, and you can tell by looking that he's never bent over a done a lick of manual labor in his life! But there is an older guy there, who really knows his beans, so all is not lost!
The tile saw I own is a cheap little piece of crap that I bought on sale - probably at Menards - for about $50. It has a 4" blade, and is like a tiny table saw with a water trough underneath. Weirdly enough, it has been an amazing saw! I've done subway tiles, 4x4s, and 12x12s with no problems.
I've also rented a big commercial tile saw from HD. It was at least a 7" blade, and maybe bigger. It is like a radial arm saw that shoots water on the blade. It was fantastic! If I tiled all the time, I'd own that saw.
That said, yes the same saw can cut both your subways and your 12x12s.
DrHicks is offline   Reply With Quote
Old 10-07-2011, 12:07 PM   #5
Hey Bud - do you ever use a tile cutter, such as this one?
I've got one, and am amazed by how much I end up using it - and how well it works. For pretty much anything that's a single, straight cut, this is what I use.
Old 10-07-2011, 12:18 PM   #6
just bought that saw at hd,"brutus" about 45 bucks, cuts great , putting down 12x12 on floor and 3x6 subway tile on walls. just finished floor an hour ago. nice clean cuts. obviously with a new blade
mazey is offline   Reply With Quote
Old 10-07-2011, 12:20 PM   #7
only had 2 tiles with a right angle , instead of renting wet saw, was able to make cuts with diamond blade on angle grinder. lot of dust. made cuts outside.
Old 10-07-2011, 12:39 PM   #8
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,074
Originally Posted by DrHicks View Post
The tile saw I own is a cheap little piece of crap that I bought on sale - probably at Menards - for about $50. It has a 4" blade, and is like a tiny table saw with a water trough underneath. Weirdly enough, it has been an amazing saw! I've done subway tiles, 4x4s, and 12x12s with no problems..
Like DrHicks, I bought a cheap little 7" wet tile saw that I used for 13" porcelain tiles on a floor and shower. It came with two blades and did the job fine for me. The cost was just a couple bucks more than renting a big saw for a day, I don't have to run into town to pick it up and return it (40mile round trip), and I get to keep it for other projects down the road.
Old 10-07-2011, 12:47 PM   #9
Tileguy
Bud Cline's Avatar
Rewards Points: 558
You'll waste more tile than you will cut successfully with one of those things.
Old 10-07-2011, 12:49 PM   #10
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Yes but mine are all Rubi brand. Use them all the time under the right circumstances.
Cutting ceramic tile away from bathtub Tomgrillo Tiling, ceramics, marble 2 03-24-2011 12:04 AM
cutting round lines on ceramic tile wombosi Flooring 3 06-21-2010 06:58 PM
Cutting tile on a diagonal kntry Building & Construction 7 09-09-2009 11:52 PM
cutting mosaic tile amakarevic Flooring 6 06-04-2008 05:02 PM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 04:31 PM
