Tile Cutting - Flooring - DIY Chatroom Home Improvement Forum
Old 01-15-2012, 10:56 PM   #1
Tile Cutting
About to get ready to tile my bathroom floor. I layed out the tile to see how it was going to come together. Using 12x12 tiles, I am ending up with about a 4 inch gap between the tile and the carpet. Is it ok to cut the tile and lay it only 4 inches wide? If so should i lay the 4 inch piece toward the door of the bathroom or the closest?
chade64 is offline   Reply With Quote
Old 01-15-2012, 11:01 PM   #2
Rewards Points: 12,808
When ever possible you want your cuts where not going to be noticed.
Most often behind the toilet, under the vanity area.
Not in front of the door or in front of the tub.
Old 01-15-2012, 11:07 PM   #3
Rewards Points: 150
Why not split the difference and make each end 8"?
joemontana16 is offline   Reply With Quote
The Following 2 Users Say Thank You to joemontana16 For This Useful Post:
Branden (01-16-2012), chade64 (01-16-2012)
Old 01-15-2012, 11:18 PM   #4
Tileguy
JazMan's Avatar
Rewards Points: 220
Definitely no 4" piece at the doorway. A small piece like that might be OK at the opposite wall, otherwise 8" on both would be best.
Jaz
The Following User Says Thank You to JazMan For This Useful Post:
Old 01-16-2012, 10:00 AM   #5
thank yall so much...makes great sense.
Cutting ceramic tile away from bathtub Tomgrillo Tiling, ceramics, marble 2 03-24-2011 12:04 AM
cutting round lines on ceramic tile wombosi Flooring 3 06-21-2010 06:58 PM
Cutting tile on a diagonal kntry Building & Construction 7 09-09-2009 11:52 PM
cutting mosaic tile amakarevic Flooring 6 06-04-2008 05:02 PM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 04:31 PM
