-   -   Which tile cutter to use for commercial flooring tiles (http://www.diychatroom.com/f5/tile-cutter-use-commercial-flooring-tiles-170497/)
amakarevic 01-29-2013 03:10 PM
I am putting (vinyl?) commercial flooring tiles in one of my hallways. The product I've seen one guy (pro) use at a supermarket once was this:
http://www.globalindustrial.com/p/to...or-tile-cutter
Now, that baby is $200+. I was wondering whether the following, much cheaper variant that to me (non-flooring-pro) seems like it does a similar job:
http://www.mansiontools.com/Contract...FQSf4AodQU0A1A
The tiles are relatively soft and I have cut them with a utility knife before (for under my washer where precision was not important) but I want a more precise tool for my hallway as they will be more exposed.
Any suggestion? Is paying $170 extra worth it. The speed is not an issue as I have time and will not be doing this very much in the future.
JazMan 01-29-2013 03:19 PM
The first is a vinyl tile cutter. The second cutter is for ceramic tiles. (Which would be a better choice for the floor, but besides the point).
You should be able to do a job like that without a cutter. use a square and a utility knife, just score and snap. There should not be any cuts that are exposed. What do you mean by that?
Jaz
DannyT 01-29-2013 03:24 PM
i was thinking the same thing about the cuts Jaz. any cuts should be covered by the base or shoe molding and transition strips at the doorways.
like Jaz said score and snap. i have used tin snips to cut around pipes before and worked pretty good.
amakarevic 01-29-2013 03:28 PM
I guess you are right, cuts will go only against the wall and will later be covered with baseboard.
JazMan 01-29-2013 03:44 PM
Square and straight edge, utility knife, torch for "hot-cuts".
Jaz
amakarevic 01-29-2013 03:52 PM
what's a "hot cut"?
oh'mike 01-29-2013 05:58 PM
On occasion a cut out for a pipe is made in the center of a vinyl tile---when this happens---heating the tile will make it soft enough to bend around the pipe without snapping--
This is also handy when getting the tile to conform to the floor as it goes into a drain --
We used to have an old fashioned electric cooking stove for that purpose when we got into a bad area---
rusty baker 01-29-2013 07:42 PM
Jaz
Exactly. Did thousands of feet of VCT, never owned a tile cutter. Did have a set of shears, made by Craftsman that would cut them when they were hot.
JazMan 01-29-2013 08:56 PM
I've never used shear to cut tiles. I mark by scribing then razor knife away.
Jaz
rusty baker 01-29-2013 09:03 PM
I only used it to cut circles and odd angles.
amakarevic 01-29-2013 09:33 PM
why not just use a jigsaw?
JazMan 01-29-2013 09:38 PM
No Jigsaw for vinyl tiles. That would be something to see.:eek: Look Ma, no fingers.
Jaz
oh'mike 01-30-2013 06:24 PM
You should be able to work all day with little more than a utility knife---aviator snips--straight edge and a propane torch or heat gun---a snap line and a ruler.
JazMan 01-31-2013 08:11 PM
Mishka,
Apparently you didn't bother to read this thread. :whistling2:
BTW, welcome. Strike one. :wink:
Jaz
oh'mike 01-31-2013 08:19 PM
That was a spammer---
