Old 06-27-2006, 03:14 PM   #1
Tile on concrete slab, ground level - bamboo?
My house is concrete slab, single story, heat via forced hot water baseboards. I'd like to replace all the existing carpet with wood, but am not sure on selection of type of flooring...
The first room I'd like to do is a small bedroom (abt 10x10) with what looks like vinyl tile over the concrete. My clearance from the top of the tile to the first interference on the heat baseboards is approximately 1 inch. The look that I'd like for this room is bamboo.
I assume I can't nail, as I don't have room to lay down both a 3/4 sheet of plywood and a 5/8 plank of bambo (well, not without adding plumbing to the project)...
Glue? Does this mean glue down plastic sheeting to the existing tile, glue red paper down to the plastic, then glue the planks to the paper?
Float? Just put plastic down, then red paper, then planks, with no adhesive between layers?
IvoryRing is offline   Reply With Quote
Old 06-27-2006, 11:10 PM   #2
Floorwizard's Avatar
Engineered bamboo floated over the proper pad warrantied by the manufacturer.
some come glueless.
oh yea, don't forget it will scratch like a wood, and keep a humidifier in the room if you can
Floorwizard is offline   Reply With Quote
Old 06-28-2006, 09:52 AM   #3
Yeah, I figure it will act (from a scratch/dent/etc pov) pretty much like wood - not a miracle or anything. I like the look, and the office will have an oriental theme to it.
Humidifier - have not heard that... you mean indefinitely, or while installing? This room will tend to be somewhat warmer than the rest of the house, as it will have a number of computers in it.
Currently the house has no AC at all - so humidity is subject to mother nature (and currently rather... um... humid!)
Extending Concrete Patio Slab bobo Building & Construction 6 04-17-2008 01:17 PM
Concrete basement slab + Radiant + Tile MageMinds Flooring 4 08-21-2007 01:52 PM
Filling hole in carport (concrete slab) chaddihimself Building & Construction 2 08-10-2007 01:50 PM
Pulling up tile and laying bamboo on concrete kdhughes Flooring 2 07-20-2007 12:11 AM
Concrete slab weeps moisture dale h Flooring 2 04-30-2005 11:29 AM
