We are wanting to paint the flooring with waterproofing paint/sealant.
Your first question should have been: Can we use a chemical to remove the existing adhesive in preparation for ceramic tile?
The answer would have been:
"No", chemicals are bond-breakers when it comes to ceramic tile installations.
Your next question should have been: Can we paint our floor with a sealer prior to installing ceramic tiles?
"No", sealers are known bond-breakers when it comes to installing ceramic tiles.
Your next question should have been: Do we have to remove all of the black vinyl tile adhesive residue in preparation for installing ceramic tiles?
"No", there are thinset adhesive mortars available that can be used over "cutback" adhesive if the floor has not had chemical adhesive removers or sealers used on it.
So...at this point...why don't you divulge the name of the secret waterproofing sealer you intend to use and we'll see what that brings to the party?
So do we need a tile membrane to prevent the tiles from shifting and cracking?
If the floor is seventy years old now and has no cracks why would the tile crack and shift?
We just want to do this correct the first time so we don't have to redo it.
Yes, I can see that!
