Tile On Concrete - Flooring - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-19-2010, 06:33 PM   #16
Tileguy
JazMan's Avatar
Rewards Points: 412
R&D is right about not using pressure treated lumber indoors, especially when tile is being installed. PT is too wet, and yes it'll shrink and twist as it dries out. Use only kiln dried lumber.
Having said that, the entire method of sleepers over concrete is not an approved method to build up a floor for the purpose of installing tile. It may work most of the time if everything is done well, but it's a high failure installation. You are likely to develop some bounce and you will trap moisture.
Jaz
Old 02-21-2010, 09:43 AM   #17
If the whole reason for raiseing the floor is the cold then save what you would spend on wood ,sealer and backer ,and just get a floor heating system and tile to the slab.Thats what I did and it worked great
clasact is offline   Reply With Quote
Tags
concrete , sleepers , tiles
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 06:10 PM
Old Tile on Concrete floor bmenton Flooring 1 01-27-2009 06:53 PM
help! tile over stained and sealed concrete gotrdun Flooring 3 08-20-2008 11:32 PM
marble tile over existing slate and concrete flooring bullrage22 Flooring 13 05-19-2008 07:58 PM
Tile on concrete slab, ground level - bamboo? IvoryRing Flooring 2 06-28-2006 08:52 AM
