Tile On Concrete - Flooring - DIY Chatroom Home Improvement Forum
Old 02-19-2010, 01:52 PM   #1
Rewards Points: 12
Tile on Concrete
Sorry in advance if this question has been answered before. I am new to this forum !
Here is my situation. I have an older home that is built on a concrete slab. The back of my house has a "screened in Porch"
which only has a concrete floor and a roof at the moment. I am going to be enclosing the room in the spring time and looking to put down a slate tile floor. I am going with tile becuase I am also going to be installing a wood burning stove.
My question is: What would be the recommened subfloor ?
Here is what I think: Concrete-Vapor Barrier-Sleepers (with foam board between)-Plywood-RockBoard-Tile.
I am not to sure what would be the correct thickness of any of these materials either, Please help thanks.
mikeydeuce is offline   Reply With Quote
Old 02-19-2010, 03:18 PM   #2
DIY staff
Rewards Points: 7,174
Concrete is the ideal base for tile--------Unless the slab is badly flawed-you are ready to tile.
If you will let us know where you are it will be easier to offer advice.
If you are in a freeze/thaw area your slate will not last to long,Slate will absorb moisture and split when frozen. Look for tiles that are Mohs 4 or harder,in freeze thaw areas.--Mike--
Your proposed floor system sounds O.K. in the room is weathered in and you want a warmer floor.
Treated sleepers,glued and screwed (tapcon)--Then vapor barrier is better.
oh'mike is online now   Reply With Quote
Old 02-19-2010, 03:27 PM   #3
Rewards Points: 12
The whole reason behind raising the floor was due to the cold. The slab itself is in good shape but to low to the ground (maybe 4 inches). I am also thinking about using Ditra instead of RockBoard
I am in Central NJ
Old 02-19-2010, 03:53 PM   #4
DIY staff
Ditra is a good choice. I've done this exact thing,using 1 1/2 " foam --9 years and good as new.
It sounds to me that you have a good grasp of how to do this one.--Mike--
If you go ahead with the slate--glaze it well before you grout.
Raw slate can be ruined while grouting.
Old 02-19-2010, 04:06 PM   #5
Rewards Points: 12
QUOTE]Ditra is a good choice. I've done this exact thing,using 1 1/2 " foam --9 years and good as new.[/QUOTE]
1 1/2 foam ? What size sleeper did you use ?
I have a good idea of how to do this. I think the best bet for me is
Vapor barrier-1inch sleeper-1inch Foam board (Sealed with foam)-1/2 inch T&G Plywood-thinset-Ditra-Thinset-Slate Tile
I also dont want to have to jump into the room when entering it
What do you think ?
Old 02-19-2010, 04:29 PM   #6
1/2"ply tothin
The older I get the better I was
Old 02-19-2010, 04:34 PM   #7
Rewards Points: 12
1/2"ply tothin
what do you suggest ?
Old 02-19-2010, 04:35 PM   #8
DIY staff
On that floor I used 2x4 sleepers---3/4 t&g ply subfloor is the MINIMUM no 1/2 to much flexing.
That is what TPOLK was trying to say--Trying to talk with a mouth full of chocolate cake,I think.
Old 02-19-2010, 04:42 PM   #9
chocolat be very good to me
Old 02-19-2010, 04:44 PM   #10
DIY staff
You want to glue the sleepers down,and use screws-- this reduces flexing and bounce.
Another benefit--Tapcons are expensive and take time to install.
Treated wood must be used against the concrete. Vapor barrier on top then your 3/4 ply.--Mike==
Old 02-19-2010, 04:54 PM   #11
Rewards Points: 12
That sounds great. The question I have now is ,Wouldnt the floor be above the Sole plate by 3/4 of an ich if I am using 2 x4 ? I will be framing the room and I do have the option of using a double Sole Plate if I can.
Old 02-19-2010, 05:01 PM   #12
DIY staff
Good plan--sure will make trimming the room easier--------
Old 02-19-2010, 05:04 PM   #13
DIY staff
Once again, Treated bottom plate.
Consider buying a roll of foam sill sealer.(3 1/4" wide foam-keeps out air and little bugs)
Old 02-19-2010, 06:16 PM   #14
NEVER use treated lumber anywhere tile is going.
What condition is the slab in, if good and no cracks, paint, sealers and is flat, Ditra, then tile.
R&D Tile is offline   Reply With Quote
Old 02-19-2010, 06:31 PM   #15
DIY staff
R&D--Have you read his requirements?
Are you concerned with the sleepers shrinking?
Bit of a smart axx thing to pop into a situation and make a comment like that without an explanation,Why did you behave that way?
Tags
concrete , sleepers , tiles
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 07:10 PM
Old Tile on Concrete floor bmenton Flooring 1 01-27-2009 07:53 PM
help! tile over stained and sealed concrete gotrdun Flooring 3 08-21-2008 12:32 AM
marble tile over existing slate and concrete flooring bullrage22 Flooring 13 05-19-2008 08:58 PM
Tile on concrete slab, ground level - bamboo? IvoryRing Flooring 2 06-28-2006 09:52 AM
