Tile On Cement Outdoors - Flooring - DIY Chatroom Home Improvement Forum
Old 02-28-2012, 12:51 PM   #1
Tile on Cement outdoors
I have built an octagon gazebo outside that has a cement floor and a fire pit in the center. I plan on putting tile down and need information on what type of product I should use for under the tiles. Thanks
fly4sport is offline   Reply With Quote
Old 02-28-2012, 12:52 PM   #2
I forgot to mention we have sub zero weather in the winter.
Old 02-29-2012, 09:16 AM   #3
Your gazebo looks amazing! I want to build an outdoor kitchen and I think I might steal your design. I'm not a qualified professional, but I think you should first level the floor (self leveling screed) and then lay the tiles. As for the tile adhesive, look for a good thin-set, designed for outdoor projects.
jacksander is offline   Reply With Quote
Old 02-29-2012, 08:41 PM   #4
DIY staff
Rewards Points: 7,174
A high quality modified thinset will work or better yet an unmodified mixed with a liquid latex--"Mud" What Is It? - Kitchen & Bath Remodeling - DIY Chatroom - DIY Home Improvement Forum
I am always nervous with outside installs--I have always used unmodified mixed with latex---never had a failure---but the risk is always there---
Make sure the slab is pitched for drainage so water does not stand in the tiles and soak into the grout.
oh'mike is online now   Reply With Quote
Tile over Tile ?? Piney Flooring 17 02-06-2012 10:59 PM
Travertine Tile Help MikeinTexas Flooring 1 09-07-2011 11:43 AM
Tile over Painted Lightweight Cement New_2_DIY Flooring 16 08-28-2011 03:29 AM
Subfloor and Porcelain tile prep sugarhousemama Flooring 4 12-03-2010 07:47 PM
Removing Linoleum to lay tile over cement floor - Need some advice dgeorge Flooring 10 10-23-2010 02:47 PM
