Tile To Carpeted Step Transition - Flooring - DIY Chatroom Home Improvement Forum
Old 09-09-2009, 03:29 PM   #1
Tile to Carpeted Step transition
I have a bathroom that is already tiled and connects to a step (down) that will be carpeted. What should I use to transition? I've looked at the Schluter products but they all seem to need to be installed under the tile. Suggestions?
scot is offline   Reply With Quote
Old 09-09-2009, 06:36 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Are you wanting to install carpet on a stair-riser adjacent to tile?
How about a picture?
XXX
Old 09-09-2009, 06:44 PM   #3
the stairs go down from the tile.
Old 09-09-2009, 07:16 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
...and you are carpeting the riser???
XXX
Old 09-09-2009, 07:23 PM   #5
yes. the riser and the rest of the stairs down into a closet will all be carpeted
Old 09-10-2009, 08:29 AM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
If the tile is flush with the riser-face a small transition can be made of wood. This transition is attached to the face of the riser at the top just below the tiles bottom edge. This transition can be any size you desire but typically would be 3/8' X 3/4" X 'width of the riser'.
This provides a 3/8" lip to tuck the carpet to/under.
The transition would be stained (maybe) to suit the surrounding color scheme.
XXX
Curved tile to carpet transition toocheaptohire Flooring 5 04-16-2009 02:37 PM
Transition laminate to higher fireplace tile Slippin Flooring 1 03-17-2009 08:22 PM
Transition from hardwood to ceramic tile. tmbrink Flooring 1 03-09-2009 12:04 AM
hardwood to tile transition navychief39 Flooring 8 03-04-2009 06:32 AM
Ceramic tile on a little step... kbens74 Flooring 8 01-04-2007 10:45 AM
